Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-28-2009, 03:52 PM   #1
Profile:  2004 25' Safari
San Francisco , California
No hot water in shower - 2004 Safair
Hello All:
I just purchased a 2004 25' Safari. A beautiful trailer with one glitch - no hot water in the shower! We get hot water in the kitchen sink and bathroom vanity. Any ideas as to what is going on?
a.moore is offline   Reply With Quote
Old 07-28-2009, 03:57 PM   #2
Profile:  2008 16' Safari
Destrehan , Louisiana
Yes, the hot water line to the shower sprang a leak and someone disconnected it or it's also posible that the shower faucet is just broken. Start tracing hot water system out. You'll find it.
dlb435 is offline   Reply With Quote
Old 07-28-2009, 05:17 PM   #3
Profile:  2008 28' Safari SE
winter garden , Florida
I would take the shower valve apart and see if someone replaced the insides, it is possible to put it together wrong and it would block off the hot water when you turn it to hot.
bob34787 is offline   Reply With Quote
Old 07-30-2009, 02:03 AM   #4
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
No hot water in the shower.
Hi, it is fairly common for the shower valve to go bad. Long story short, replace the cartridge in the shower control. I know because I have been there and done that. I took mine all apart, cleaned, and checked everything. It still didn't work. I bought a new part from Home Depot and it has been working ever since. As for installing it wrong, if you put it in backwards, the water will be hot first and then cold as you turn the handle. [as per Moen]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 11-05-2009, 06:56 PM   #5
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Hot Water
I just had mine go out when I went on the road last month.Darn hot water was running low at full blast.I looked behind the sink and noticed water on the wood floor and then inspected as much as I could.I figured it was the faucet itself that finally crapped out.I am going to take it apart tomorrow and fix the leak.
What type of sealant did you all use to seal the edge up on the faucet when you replaced it.Bathtub sealer or something else.Thanks All.
Blue Numbers and Signs
E-mail me for quotes.
Devoman is online now   Reply With Quote
No Hot water in Shower...ugh. Brow324 Sinks, Showers & Toilets 14 11-20-2009 11:31 AM
no hot water in shower Susand Sinks, Showers & Toilets 4 04-18-2008 03:27 PM
No shower hot water Resorts Plumbing - Systems & Fixtures 3 07-11-2007 09:16 AM
How Hot Should My Shower Be ? B4WEDI 2006 Bambi - all models 22 02-03-2007 10:51 PM
Only hot water coming out of shower. TBKP's Overlander Plumbing - Systems & Fixtures 6 06-21-2003 03:41 PM
