Old 07-28-2015, 07:25 PM   #1
2008 27' International CCD FB
Lakeway , Texas
No hot water in shower
HELP! We're on the road and the shower is not getting any hot water.
The water "flows" in the hot position but no hot water. All other faucets and hot water heater working fine.
Do you think it is the shower off/on valve?
2goldens is offline   Reply With Quote
Old 07-28-2015, 08:05 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Can you confirm that your water heater lit and stayed lit? The light on the switch panel should come on and then turn off and stay off. You should be able to hear the burner working. Are the valves at the heater in the proper positions (the ones in the lines to and from the heater in line with the pipe, the bypass across the heater perpendicular to the pipe)? As you turn the temperature valve from the cold position to the hot position, does the pressure and/or flow change? This would indicate that the valve is working.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-28-2015, 08:17 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Shower water valve, if mowen maybe screw is loose.
Old 08-24-2015, 08:10 AM   #4
Venice , Florida
When you find an answer, please post. I have the same issue, same trailer, and a Moen valve. We are on the road also...20 miles from town in campground. I have a dribble of lukewarm water.
brerfox6 is offline   Reply With Quote
Old 08-12-2017, 08:41 PM   #5
2007 27' International CCD FB
San Diego , California
I know this is an old thread. But just went through this and thought I'd post an answer to help the next person.
Definitely the moen shower cartridge.
2007 27FB Ocean Breeze "See Turtle"
2009 Lexus LX570
pteck is online now   Reply With Quote
Old 08-12-2017, 08:56 PM   #6
The cartridge is a Moen 1222.
There are several variants: 1222, 1222B, and 1222HD, and many 3rd party equivalents. There's also a rebuild kit for ~10.
It's been said that Moen parts are for life you may be able to get a free replacement directly from Moen via their support line.
2009 Lexus LX570
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
