Old 06-28-2009, 04:19 PM   #1
Andreasen's Avatar
1974 29' Ambassador
Fresno , California
Question No Cold Water from Shower Faucet!
This weekend we discovered we had no cold water comming from our shower, also very little water pressure. After reading our 1974 Airstream service manual, it looks as if the Shower Mixing Valve is the culprit. The cartridge needs to be replaced, and the retainer clip was broken. We have a 1974 29' Ambassador Rear Bath Airsteam. The shower faucet does not have a brand name on it. Can anyone help us to obtain replacement parts? Thank you!
Andreasen is offline   Reply With Quote
Old 06-28-2009, 04:51 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
It`s a Moen call them 1-800-289-6636,they will send you a new cartridge and clip,they have good customer service. Dave
PS it sometimes requires a puller to get the old cartridge out,you can probably rent one at HD or a good Ace hardware
easyride is offline   Reply With Quote
Old 06-28-2009, 05:01 PM   #3
Ottawa , ON
Here's my post on exactly that same scenario, albeit in the kitchen, not the bathroom. However, it's exactly the same part, so you might expect the same results. Skip down, the part you want to read is nere the end of my post.
Make sure you have lots of white vinegar on hand...
Old 06-28-2009, 05:02 PM   #4
Andreasen's Avatar
1974 29' Ambassador
Fresno , California
Thank you so very much for the quick response!
Old 06-28-2009, 08:28 PM   #5
Andreasen's Avatar
1974 29' Ambassador
Fresno , California
I actually found the Moen cartridge and retainer clips at Home Depot, with the same part number as in our manual! The Core Puller Tool for Moen was also available, I bought it, but will return it if not needed. Thank you Airstream Forum!
shower water valve, water is cold!!! cnsilver Sinks, Showers & Toilets 3 11-02-2008 06:51 AM
Shower faucet Philip Williams Sinks, Showers & Toilets 11 02-09-2007 06:55 PM
Shower faucet replacement racoco 1974 - 1979 Sovereign 6 10-30-2006 02:38 PM
Shower faucet repacement gergstuff All Argosy Trailers 4 08-02-2006 11:41 AM
Shower Faucet wa3vez Mechanics Corner - Engines, Transmission & More... 2 08-30-2004 02:39 PM
