Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-03-2009, 09:16 PM   #1
Spokane , Washington
Newbie with leaking shower faucet
I Just picked up our 2006 25FB SE and we are very excited. The only "problem" we have is that the shower faucet does not shut off completely. I am familiar with Moen faucets and before I replace the cartridge, I was wondering if this thing has some sort of adjustment.
When you turn the valve all the way to the right, water still dribbles from the shower head. This is only about 3 years old an has not even been used that much. Could the cartridge go bad so soon?
aftermath is offline   Reply With Quote
Old 10-03-2009, 09:43 PM   #2
Alwhisman's Avatar
Profile:  1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 70
Airstream Registry
Send a message via Yahoo to Alwhisman
Sitting can do as much damage as abuse. Could have picked something up out of the line as well. Have you pulled the valve out to look at it? You can get valve kits, or the complete insert. The kits are relatively inexpensive.
As far as adjustments, I'm not familiar with which faucet you have, the only adjustment I know is an adjustable ring that will limit hot water (temperature control)
Alwhisman is offline   Reply With Quote
Old 10-03-2009, 10:12 PM   #3
Profile:  Corona , California
Many times a Moen faucet can be repaired, by replacing the "O" rings on the cartridge.
Worth a try before replacement.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-04-2009, 05:31 PM   #4
Thanks for the helpful replies. I decided to replace the cartridge but will keep the old one in case I need to rebuild one in the future. Everything went well and it works great.
Now all I have to do is figure out where we are going to store everything. There isn't a lot of outside storage on this unit. I suppose I will be loading more stuff in the back of the pickup.
Old 10-04-2009, 05:39 PM   #5
Alwhisman's Avatar
Dayton , Texas
Images: 70
Airstream Registry
The storage issue took us awhile. I found out I usually brought too much as it is. We have a permanent stock of the basic (cookware/kitchenware/linens. etc) so we dont have to deal with that every trip.....just our clothes and food. Bigger items I carry in the bed of the pickup (grill/generator/bikes)
Took a few trips to smooth it out, but still working on it...
.......glad your faucet was an easy fix!
Al
71 Kitchen Faucet Leaking Lumatic Sinks, Showers & Toilets 8 08-12-2009 08:44 AM
How to remove/repair leaking B/R faucet azfiredog300 Sinks, Showers & Toilets 6 10-25-2008 11:59 PM
Leaking kitchen faucet 99Limited34 Plumbing - Systems & Fixtures 4 10-17-2008 10:35 AM
Shower Faucet wa3vez Mechanics Corner - Engines, Transmission & More... 2 08-30-2004 02:39 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
