Happy anniversary!
Good job with the plumbing! You may have a water system like ours--there was no pump, but there is a valve for attaching a bicycle pump to pressurize it. We plan to get a pump in (actually two, but too much to explain right now), fwiw!
Have you checked your flooring for rot? Sounds like you've been probing it to get at the pipes. Are all the side connections solid and the frame fully attached? That's another issue we've been dealing with (see the beginning of my blog for the whole dirty story).
Don't worry about a heater for now! If you want, start looking now for a "Portable Buddy Heater" on sale or used (you may get a deal this time of year). It's essentially a portable catalytic heater--and will give you good heat until you decide what to do down the road. There are lots of options to consider. When you've found your solution, the heater is also nice to bring out to early/late season rallies--you'll be a popular fellow if you bring a heater to happy hour!
Mary
Originally Posted by okjoek
Wow, thanks for all the responses. You are right I'm sure, use the search feature before you ask a question that has been asked dozens of times. I am glad to hear water isn't supposed to stay in the bowl, that does make sense, no more sloshing than necessary. I will look to see on this forum what was the standard unit in 64. I would assume there would be a standard brand.
As for the structural of the trailer I'm sure I need axils, but for now I believe I will just replace the bearings. There are about 5 or 6 lakes about 30 to 45 minutes away and for the summer thats all we'll do. This winter I'll try to get the tires and axils done.
The stove works, haven't checked the oven or the furnace. Right now I don't care if the furnace works. I haven't found any gas leaks. I also haven't checked the water heater. The water pump seems to be missing, at least I can't find it though when I put water in the tank it ran out a line that wasn't connected to anything, I guess the pump's position. I fixed all the faucets and leaks in the lines, it wasn't too bad. The air conditioner cools but the fan doesn't blow, that will have to be addressed
I think I am close to trying it out. I am leaving town for New Orleans on Friday (26 wedding anniversary and the wife thinks we need to do something) so I can't play this weekend.
Joe
