Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-30-2008, 04:16 PM   #1
Profile:  1984 34' Excella
beaufort , South Carolina
new shower adapter?
i have a 84 airstream and i wanted to replace the shower head and hose when i took the old (original) off i noticed it has an adapter glued to it that makes it able to connect to the wall part so i can not get a standard shower head for my airstream a standerd has the threads on the inside the adabter makes the threads on the outside any ideas about this adapter and where i can get one
kiltchick84 is offline   Reply With Quote
Old 06-30-2008, 08:27 PM   #2
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Hi - Can you post a photo of the set up you have now - someone may be able to come up with a solution for you then.
GARY
OHIO - WE ARE THE MOTHER SHIP
Charter Member - NOVA
WBCCI - 5308
Old 07-01-2008, 02:39 PM   #3
Tom Nugler's Avatar
Profile:  1972 25' Tradewind
McHenry County , Illinois
Lightbulb The Hard Way
I had a similar problem with the shower but reversed from your situation.
The fixture on the tub was leaking beyond repair so I picked up what I thought was a close replacement. After replacing the leaking faucet the original hose to the shower head wouldn’t fit. I definitely wanted to keep the vintage sprayer in place.
I took both pieces to the hardware store and matched each one up on the board that displays all the different adapters. Try every fitting you can find. Maybe you’ll get lucky. I didn’t.
My solution was to buy the two that fit the faucet and hose, cut off the threads that didn’t fit, and silver soldered the two together.
While I faced the treads off with a lathe, careful work with a saw and file should work fine. The brass fittings solder easily with a small torch.
Well, now that I’ve given you the hard way to do this someone will probably post a direct replacement part number, price and ordering info.
Good luck,
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Sewer Hose Adapter kjj422 Waste Systems, Tanks & Totes 12 07-23-2008 11:28 AM
4 to 7 pin adapter ? Dan S Towing, Tow Vehicles & Hitches 24 03-10-2007 07:01 PM
Adapter Daisy2 Electrical - Systems, Generators, Batteries & Solar 7 03-24-2006 07:51 AM
Handfree Cellphone Adapter Krazykraut Off Topic Forum 4 02-18-2003 02:48 PM
Adapter / Electric from garage? bkpine Electrical - Systems, Generators, Batteries & Solar 8 08-13-2002 08:22 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
