Old 10-15-2010, 10:03 AM   #1
Confused in Bham
1964 24' Tradewind
Bellingham , Washington
New Challenge - Shower drain
So I've got a bit of a challenge. My shower is behind the single axle, and is almost directly above the black tank. Due to lack of real estate, the grey tank is in front of the axle.
I am thinking that I will need to attach a pump below the shower drain to get it to the grey tank. Anybody done this or have any thoughts on how to best do it?
Thanks!
Beyond
beyond is offline   Reply With Quote
Old 10-15-2010, 10:25 AM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
ya could raise the base height in order to increase the "fall"
in the drain line - water wants to go downhill. i would avoid
pumps if at all possible - gravity is best
kennethowens is offline   Reply With Quote
Old 10-17-2010, 02:04 PM   #3
Confused in Bham
1964 24' Tradewind
I still don't think I have enough drop though. As it is I am 6 feet tall and can't go up much without losing too much head space.
-B
Old 10-17-2010, 02:40 PM   #4
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Ideally you solve the problem w/out a pump . . . however there are systems designed for this situation, look at Marine Parts Stores/Websites. If you go this route, make sure you design it so you can service the pump/drain as it will most likely need it at some point.
(it seems like you could move your grey right next to your black tank and drain directly into it . . .)
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 10-17-2010, 03:26 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If you lower your tank a couple of inches,you should have plenty of fall,you even have a closet between them to run your vent thru the roof. Dave
easyride is offline   Reply With Quote
Old 10-17-2010, 09:29 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Beyond
That kind of setup is not uncommon. I believe that Scamp makes a couple trailers that are set up like that from the factory. Maybe it's another maker. Anyway, not unusual.
Take a look at products like the Jabsco Filterless Bilger
Jabsco Filterless Bilger Sink Shower Drain Pump - 50880-1000 - BoatersWorld.com
It is self priming and can be run dry without damage so you can set it up in a cupboard where you can get at it, with no sump, and it doesn't require a filter.
It's going to be loud and it is one more thing to break but if the geometry won't work out any other way you're stuck.
Old 10-18-2010, 01:29 AM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Originally Posted by Jammer View Post
Beyond
The showers in my sailboat drain into a sump and are pumped out with a Jabsco diaphragm pump. The pump is not really a problem but you really do need a screen type strainer on the suction side and they plug up frequently with hair. On a sailboat you really don't have a choice.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 10-18-2010, 07:53 AM   #8
Attachment 113127
Thanks!
Beyond
Your potable water tank, as shown in your drawing, is in the wrong end of the trailer. It should be forward of the axle or up front.
Old 10-18-2010, 10:27 AM   #9
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I have never seen a proposed potable water tank in the rear. It will adversely affect handling and also cause the trailer to have improper tongue weight.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-18-2010, 01:45 PM   #10
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
i used a pump - a whale gulper - as we put the grey tank above the floor. yep, its loud. but it does the job. no filter, can run dry... want to hard to install.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Shower drain Paul Dobbin Land Yacht/Legacy Motorhomes 9 07-05-2016 08:20 AM
Shower drain willyd Sinks, Showers & Toilets 0 11-25-2008 08:35 PM
Shower Drain Corroded Moonstruck Sinks, Showers & Toilets 2 08-13-2007 02:33 AM
Shower Drain Dbraw Sinks, Showers & Toilets 1 03-12-2003 10:59 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
