Old 09-05-2008, 01:58 PM   #1
rogerdodger's Avatar
Fresno/Clovis , California
New Bath Sink-short pipes
I bought a new sink for my bathroom, bur the connectors are shorter than the old sink. The pipes from cold and hot water are too short. They are made of black plastic pipe with connecter on with a permanenet clamp. the end to the water system is clamped with regular clamps.
Question, can I buy new black pipe, use regular clamps on both ends??
HELP
Roger
rogerdodger is offline   Reply With Quote
Old 09-05-2008, 04:30 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
If I understand the problem you can go to any hardware store and buy a straight through connectors (male on each end) that will allow you to add a short piece of regular hot & cold water as an extension.
Talk to someone in the plumbing section they can help you.
Garry
Old 09-05-2008, 05:20 PM   #3
My problem is, the end that connects to the water supply(hot and cold) is a slip fitting with clamp, rather than another thread,like the hoses from a hardware store(lowes etc) any suggestions??
Roger
Old 09-05-2008, 05:41 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
They sell an item at Lowes and HD that is called a Sharkbite fitting that will allow you to cut your existing pipe and adapt a screw on fitting to the pipe. Easy to use in tight locations - they just snap together. You can then use the flex lines for a home sink in braided stainless steel and be done with the plumbing stuff.
SharkBitePlumbing.com | Instant Push Fittings for CPVC, Copper and PEX Tubing
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-05-2008, 06:02 PM   #5
Ok. Thanks, Michael, I will check it out at Lowes. Gotta love this website.
Roger
No water to sink or bath dogwood Fresh Water Systems 4 05-20-2008 09:09 PM
Water pooling in bath sink altamont Sinks, Showers & Toilets 12 10-16-2007 08:02 AM
need new bath sink faucet KHarris Sinks, Showers & Toilets 3 09-05-2006 10:31 PM
leaky bath sink faucet maxandgeorgia Sinks, Showers & Toilets 1 08-05-2006 02:19 PM
Refurbish bath sink advise/71 Globetrotter LarryD Sinks, Showers & Toilets 8 04-03-2005 12:39 AM
