Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 04-06-2013, 05:35 PM   #1
1981 31' Excella II
New Market , Alabama
Need simple shower head with cutoff
I am looking for a simple shower head that has a good reliable thumb operated shutoff lever/button. The one I have has several positions and to turn it off you have to use both hands and the off position closest to the normal shower position leaks. It is a major pain and wastes water. This fills the gray water tank too fast. I don't need multiple positions and we are almost never hooked to sewer since we mostly stay in state parks that don't have sewer at the sight.
Perry
Old 04-06-2013, 06:12 PM   #2
Bruce B's Avatar
2021 25' Globetrotter
Jamestown , Rhode Island
I purchased one of these for our Airstream replacement shower.
Somewhat pricey but beautifully made, easy to use and forever reliable.
Bruce
100% Shower Head Shut Off Valve - Solid Brass - Chrome Finish - Amazon.com
Bruce B is offline   Reply With Quote
Old 04-06-2013, 06:59 PM   #3
1981 31' Excella II
Thanks Bruce but I really want something that I can operate with the same hand that is holding the shower head. It would be high up on the handle.
Perry
Old 04-06-2013, 07:08 PM   #4
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
We found a simple in line cutoff with a round pin pushed easily with the thumb holding the shower head. In stock at the big box hardware stores.
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 04-06-2013, 07:21 PM   #5
1999 25' Safari
Carlsbad , California
I recently purchased an Oxygenics Body Spa model and it is a big improvement over the original shower head. It uses less water, provides much more water pressure, has a convenient shut-off valve and cost about $40. I highly recommend it.
Jfuller678 is offline   Reply With Quote
Old 04-06-2013, 07:49 PM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
These are fine if you don't mind one that does not shut the water off completely, and just lets it dribble a bit. I don't like the dribble. I want complete shut-off. If you want complete shut-off then you need to go with a ball valve one like Bruce suggested. I have the same one. It is pricey, but it works, and I imagine that it will last forever.
Now Perry, it does take two hands to operate. You can't have everything.
Dan
Old 04-06-2013, 08:58 PM   #7
1981 31' Excella II
I remember the shower in my old 5th wheel that I lived in, in college that had a simple lever under the head at the head end of the handle that you could just push with your thumb while you were holding it. I expect it was some sort of ball or plug valve. It worked and did not leak. Both the wife and I were amazed at how long a shower you can take with 6 gallons of really hot water. We are starting to use our shower now but if you are camping more than a couple of days showers are a no no unless you carry an external tank and that is just one more thing to have to deal with. That is about as much trouble as just pulling the trailer to the dump station every two or three days.
Perry
Old 04-06-2013, 09:12 PM   #8
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Bruce
Just placed our order for one of these. Thanks for the tip.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 04-06-2013, 11:36 PM   #9
dznf0g's Avatar
Oswego , Illinois
Same thing as posted above, but in bronze. This can either be installed just below the shower head and could be operated by one hand. I preferred to install at the wall end of the shower hose for two hand operation. nice fixture.
Overhead Shower Water-Volume Control, Oil Rubbed Bronze Finish - By Plumb USA - Amazon.com
-Rich-
Old 04-07-2013, 12:56 AM   #10
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
We used one of these shower cutoffs, but when we purchased a new Oxygenics shower head, the shutoff is now included in the shower head and works great. This is a much improved shower over the original included by Airstream. It gives a more intense shower and uses less than half the water of a conventional shower head. If you're using water from your internal tank, this is great for reducing water usage.
wolverine is offline   Reply With Quote
Old 04-07-2013, 05:25 AM   #11
Vintage Kin
Fort Worth , Texas
I added a push-button valve at the base of the shower head. HD or Lowes. Just fine for one-handed op.
Old 04-07-2013, 05:37 AM   #12
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Is this it?
DANCO Shower On-Off Push-Button Flow Control-89184 at The Home Depot
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 04-07-2013, 06:38 AM   #13
dznf0g's Avatar
Oswego , Illinois
I really wanted an oxygenics, but they don't make one in bronze.
-Rich-
Old 04-07-2013, 07:06 AM   #14
reinergirl's Avatar
Hollis , New Hampshire
Yes they do!
Oxygenics 54535 IntelliShower Handheld Showerhead, Oil Rubbed Bronze - Amazon.com
reinergirl is offline   Reply With Quote
Old 04-07-2013, 07:21 AM   #15
1981 31' Excella II
I was thinking of this. It has good reviews. I know it does not have good Feng Shui but all I care about is that it work.
Camco 43712 RV Off-White Shower Head with On/Off Switch : Amazon.com : Automotive
Perry
Old 04-07-2013, 10:14 AM   #16
spenfolder's Avatar
2006 16' International CCD
Salt Lake City , Utah
Perry
Perry,
I have the Camco because I wanted a shut off in the handle. The shut off button is very stiff and hard to move, and the head still drips a little even in the off position. The price is right, and I still use it, but I will replace it if I find one with a better shut off.
Stan
Salt Lake City
Stan
Salt Lake City
spenfolder is offline   Reply With Quote
Old 04-07-2013, 11:43 AM   #17
2022 Atlas
Homosassa , Florida
We bought one at Wal mart. Simple on or off.
Tater is offline   Reply With Quote
Old 04-07-2013, 11:50 AM   #18
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Note that the small constant flow when these showerheads are "off" is a feature, not a bug. It is deliberately designed that way so you know the main valve is still turned on. It my not be the way you want it to work, but it is deliberate.
I had an Oxygenics in my house until a major remodel and it had a very clumsy shutoff, a rotary thingie, but now with the pushbutton I may upgrade the moho: I really like the spray design.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
TerraYacht is offline   Reply With Quote
Old 04-07-2013, 12:09 PM   #19
1981 31' Excella II
I have found that while using the pump to take a shower that you have to have the flow rate above a certain threashold or the water temperature flutuates as the pump cycles on and off. I use the pump 100% of the time till I can find a pressure regulator that actually works as opposed to being used to throw at ferrel dogs. I have not looked at Walmart yet.
Perry
Old 04-08-2013, 06:41 PM   #20
Vintage Kin
Fort Worth , Texas
Originally Posted by eljay View Post
Yes, has been used over 200-times. Placed at base of shower head/wand.
