Old 07-19-2013, 11:09 AM   #29
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by perryg114 View Post
The problem I am having with shutting the shower all the way off causes really hot water to come out the next time it is operated especially using the pump. I expect a variable flow pump or accumulator would help with this problem. I expect this is caused by the air bubble in the hot water tank that keeps the pressure higher on the hot water side making the hot water flow faster than the cold water side when opening the shower head.
Perry
The flow may differ for various reasons downstream of the pump on the hot and cold sides, but the PRESSURE when the shutoff valve on the shower is closed is going to be equal through the entire system. You'd have to have 2 isolated systems with 2 pumps to have different pressure on the hot and cold sides.
— David
Old 07-19-2013, 11:09 AM   #30
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by loechli View Post
Thanks I saw that last night online,
Does anyone have this sprayer, does it shut off completely or trickle,
my original 1972 white shuts off completely and we really like that feature.
It's a trickle. Why do I snicker when I say that
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 07-19-2013, 03:43 PM   #31
1981 31' Excella II
New Market , Alabama
The pressure is the same when there is no flow but as soon as the shower head is opened the pressure in the cold water line drops lower than the hot water side because the hot water tank acts like an accumulator and keeps the pressure more constant. An accumulator down stream of the pump would reduce this. Once the pump starts running, the water temp stabilizes.
Perry
Old 07-19-2013, 04:09 PM   #32
DKB_SATX's Avatar
1976 Argosy 28
Perry
I still think you're confusing pressure with flow. There's no backflow preventer between the water heater inlet and the cold lines, so any pressurization that might be provided by the air bubble in the water heater is going to push both directions equally (toward the inlet and outlet) and pressure measured in the hot and cold lines would be the same or so close the difference wouldn't be relevant.
For the system in question (and under any normal conditions) we can consider water to be an incompressible fluid so you'd have to have something that made the hot and cold lines 2 distinct systems to get a pressure difference between them.
— David
Old 07-19-2013, 05:36 PM   #33
1981 31' Excella II
Don't lecture me on fluid mechanics I have two degrees in it.
Perry
Old 07-19-2013, 11:43 PM   #34
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
I noticed no mention of the other variable: the heater for the tank is probably heating so the pressure in the tank will increase compared to the cold water static pressure...if there is a check valve. Otherwise, as noted, it would back-pressure and increase the entire system. However, in my moho, the tank is very close to the shower so there is may be more increase in this short feed. By observation, when I use the valve for zero flow, there is a brief "spurt" of hotter water, so I use the trickle valve.
I'm about to replace my OEM shower head with an Oxygenics. I had one of those in my house a few years ago & really liked it.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 07-20-2013, 06:22 AM   #35
1981 31' Excella II
Whatever the cause, you can get scalded and that is not good. I have not used my shower much with an external water supply and I am sure that will help with this issue. The main issue with cutting the water all the way off is saving water when you don't have a sewer hookup. There is enough hot water but not enough gray tank to leave it running. The accumulator or variable flow pump or both should help with this. At low water flow the pump is turning on and off and the pressure is all over the place. Getting rid of the pulsation is the fix whatever the exact cause.
Perry
Old 07-20-2013, 07:32 AM   #36
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Perry
Scalding water would not be acceptable and I don't know why you have it. I have a low flow shower head, 1.5 gpm I believe, a constant speed pump, no accumulator, and a zero flow shutoff valve just upstream of the shower head handle, see photo. I get a small variation in water temperature when I turn the water on, but no big deal. It is definitely not a problem. The zero flow ball valve works so well that I use it alone to turn the water on and off. I keep the shower flow control valves open and adjust water flow/temperature as needed.
Dan
