Old 04-07-2013, 07:21 AM   #15
1981 31' Excella II
New Market , Alabama
I was thinking of this. It has good reviews. I know it does not have good Feng Shui but all I care about is that it work.
Camco 43712 RV Off-White Shower Head with On/Off Switch : Amazon.com : Automotive
Perry
Old 04-07-2013, 10:14 AM   #16
spenfolder's Avatar
2006 16' International CCD
Salt Lake City , Utah
Perry
Perry,
I have the Camco because I wanted a shut off in the handle. The shut off button is very stiff and hard to move, and the head still drips a little even in the off position. The price is right, and I still use it, but I will replace it if I find one with a better shut off.
Stan
Salt Lake City
Stan
Salt Lake City
spenfolder is offline   Reply With Quote
Old 04-07-2013, 11:43 AM   #17
2012 30' Classic
Homosassa , Florida
We bought one at Wal mart. Simple on or off.
Tater is online now   Reply With Quote
Old 04-07-2013, 11:50 AM   #18
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Note that the small constant flow when these showerheads are "off" is a feature, not a bug. It is deliberately designed that way so you know the main valve is still turned on. It my not be the way you want it to work, but it is deliberate.
I had an Oxygenics in my house until a major remodel and it had a very clumsy shutoff, a rotary thingie, but now with the pushbutton I may upgrade the moho: I really like the spray design.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 04-07-2013, 12:09 PM   #19
1981 31' Excella II
I have found that while using the pump to take a shower that you have to have the flow rate above a certain threashold or the water temperature flutuates as the pump cycles on and off. I use the pump 100% of the time till I can find a pressure regulator that actually works as opposed to being used to throw at ferrel dogs. I have not looked at Walmart yet.
Perry
Old 04-08-2013, 06:41 PM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by eljay View Post
Yes, has been used over 200-times. Placed at base of shower head/wand.
Old 04-08-2013, 06:54 PM   #21
dznf0g's Avatar
Oswego , Illinois
Originally Posted by reinergirl View Post
Ok, it's what I mean , not what I say! , They don't make the small head water saver unit with the powerful blast.
This one:
http://www.oxygenics.com/Shower-Head...ower-Head.html
-Rich-
Old 07-18-2013, 02:55 PM   #22
1972 27' Overlander
Saline , Michigan
I have what I believe to be the original 1972 Alsons shower wand in my 1972 trailer.
It recently started leaking at the spray head. We do a lot of boondocking , no city water connection and the off pushbutton on the shower head is very nice to conserve water. I really like being able to quickly shut off water with one hand, not just turn to a trickle. Does anyone know of a replacement that will function the same, It sounds like the Oxygenics are very nice but "trickle" water, not shut off. It may sound small, but as my trailer has no grey tank when we boondock every cup of gray water has to be carried away by yours truly.
loechli is offline   Reply With Quote
Old 07-18-2013, 09:49 PM   #23
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Go to the plumbing section at Home Depot or any other big box store (or Amozon.com) and get an inline 1/4 turn shutoff valve (see posts #2 and #8 for a link to Amazon http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 ). Put one on mine and it works great.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-19-2013, 08:02 AM   #24
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I like the Oxygenic shower head but looks to be attached directly to the supply line. Our AS has the shower supply hose attached low down at the faucet controls and held in place by a small plastic hanger. What choices are available. The faucet is working well and I don't need to replace it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-19-2013, 09:02 AM   #25
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Here is a link to the direct Airstream replacement. They sell them at Out-of-doors-mart...
Chrome Shower Head 601358-100 [601358-100] - $37.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 07-19-2013, 09:39 AM   #26
1981 31' Excella II
The problem I am having with shutting the shower all the way off causes really hot water to come out the next time it is operated especially using the pump. I expect a variable flow pump or accumulator would help with this problem. I expect this is caused by the air bubble in the hot water tank that keeps the pressure higher on the hot water side making the hot water flow faster than the cold water side when opening the shower head.
Perry
Old 07-19-2013, 09:59 AM   #27
1972 27' Overlander
Saline , Michigan
Thanks I saw that last night online,
Does anyone have this sprayer, does it shut off completely or trickle,
my original 1972 white shuts off completely and we really like that feature.
Steve
Old 07-19-2013, 10:46 AM   #28
1972 27' Overlander
Saline , Michigan
I see the quarter turn option, but prefer the pushbutton show below
DANCO Shower On-Off Push-Button Flow Control-89184 at The Home Depot
What I would really like is a replacement to my "old outdated" 1972 alsons that has an integrated pushbutton shutoff that turns shower "off" not just a trickle, I know there are ways to do the job with additional 1/4 turn shutoffs, but it is sounding like that just might be a case of older is better.
I just got off the phone with Delta tech support, they bought Alsons several years back, I was told ALL there shower heads with shutoff do not "shutoff" just trickle.
Steve
