Old 04-18-2012, 11:25 AM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
need rubber gasket
Our 66 Safari toilet has a copper line running into the back of it. This line is for flushing/filling bowl when the lever is stepped on. There is a rubber( hard rubber or petrified rubber) gasket that the 1/2" copper line fits into. When you flush the toilet water weeps/seeps out of it. I took the gasket out and it is broken in several places ...Is there anyone that makes replacements... I don't see any markers on the bowl itself , but the flush mech. says Slide-o-matic
goshawks00 is offline   Reply With Quote
Old 04-18-2012, 12:40 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
A thread and a link within to another thread that may help you - apparently your toilet was mfg. by Thetford:
http://www.airforums.com/forums/f446...let-45770.html
Old 04-18-2012, 02:12 PM   #3
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Thanks Gary, I read that thread but it is about the Slide-0-matic unit itself. That isn't the issue, it's the rubber grommet that the 1/2"water line goes through on the toiletbowl it's self that I need. Still trying to figure it out but no luck so far.
Old 04-18-2012, 08:03 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Any chance you can post a picture of the line/fitting....
Old 04-18-2012, 08:50 PM   #5
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
well can you belive it... I found a grommet for the waterline. I ended up using a PVC grommet that fits into an old valve cover..ha-ha. Hotrods rule!!
