Old 07-23-2007, 07:55 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Need new seal if toilet pulled?
I need to take the toilet out of my trailer in order to change the carpet. (Yes, the same one that ate the PO's toothbrush!) Will I need a replacement seal if I pull the toilet out? I'd like to be prepared so I can put it back on & not have to wait for parts. I'm going to replace the carpet with some kind of linoleum & plan to place it under the toilet. Any words of wisdom with that whole can of worms? Thanks in advance!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-23-2007, 08:28 PM   #2
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I would imagine that it would be a good idea to replace it as the rubber will likely be a little hardened at best and may not come off cleanly. It is probably better to be prepaired for something simple as this. Besides it will be cheap.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 07-23-2007, 08:42 PM   #3
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Yes, replace everything that seals while you can get to it.
Imagine it leaking on your first trip.
Imagine that can of worms, then toss your cookies.
Put a turn off valve in line too.
klattu is offline   Reply With Quote
Old 07-24-2007, 08:43 AM   #4
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
yes replace it, make it right once...
it is so much painful to remove a toilet that you don't want to go back...
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 07-24-2007, 09:14 AM   #5
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
If the seal is like the wax rings found in home plumbing, I would definately replace. Even if it isn't, I'd be inclined to replace. Also make sure you clean the area where the old seal was placed. This might also be a good time to inspect, clean or replace any parts that would be a pain the tushie to do if it was all connected.
Are the seals wax like the kind you find on house plumbing???
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 07-24-2007, 09:37 AM   #6
Aria's Avatar
1967 20' Globetrotter
Sauquoit , New York
Mark's RV has the toilet gasket. Very nice people to deal with. Very knowledgeable and fast service. His name was given to me by Mel on this forum. We are forever grateful.
Aria is offline   Reply With Quote
Old 07-24-2007, 01:06 PM   #7
Toilet gaskets dry out and crack.
They are really inexpensive to replace.
Most RV toilets are held down with two bolts sticking up through a flange. Sort of like your household toilet.
There are no wax seals.
I always look at it as if I am putting something back together that will not be replaced for a long time.
Anon is offline   Reply With Quote
Old 07-24-2007, 02:50 PM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Great plan, but
Originally Posted by beckybillrae
... I'd like to be prepared so I can put it back on & not have to wait for parts. ...
Unlike home toilets, I found that there are A LOT of different gaskets for RV toilets as the flange/toilet interface was not standardized in the earlier years.
You may want to make plans to take your old gasket down to the RV parts house to match it with a suitable replacement.
Tom
Old 07-25-2007, 06:09 PM   #9
Becky B.'s Avatar
1964 17' Bambi II
Thanks for your responses. I guess I should go with the new gaskets & turn off valve. I looked them up at Mark's RV & it comes to about $60 plus the shipping. I'm wondering if I would be better off putting in a new toilet, since you can get one on ebay for between $100 & $150. I think this is an original toilet & the people who I bought it from stayed in it for about 6 months out of the year. That's a lot of use! What do you guys think & what's a good toilet? We won't be using it much (men hunting/women using it for 1-2 weeks out of the year), so it doesn't have to be the queen's throne or anything. Are they universal to the hole in the floor, or does work need to be done to them to retrofit them? I have a Thetford Galaxy in there right now. Thanks
Becky
1964 Bambi II
1988 Avion 32S
Old 07-25-2007, 06:26 PM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Maybe this will help:
Permanent Toilet Conversion Chart
Old 07-25-2007, 06:41 PM   #11
lewster's Avatar
Naples, FL , Hood River, OR
Hi Becky,
I've worked on a fair # of bowls, and I always replace the flange seal when removing/replacing the unit. While it's out, it's also a good idea to replace the blade seal, as they wear over time as well.
OTOH, A toilet with a new porcelain bowl would definitely spruce up your rig! For the difference in the price of the new seal kits vs. the cost of a new toilet, that might be the way you want to go.
Plus, it will take way less time to install a new one rather than removing and disassembling the old one, replacing all of the seals and putting it back in.....and don't forget the water valves and pedal springs if you're re-building the old one.........maybe the new unit is looking better all the time.
Just be sure that the height of the new unit is the same or similar to your existing unit..........................
Old 07-25-2007, 07:04 PM   #12
1972 29' Ambassador
Tucson , Arizona
You always put a new seal in when you pull a toilet, home or RV.
T
tamis is offline   Reply With Quote
Old 07-25-2007, 07:11 PM   #13
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
The only right way to do it is to replace the seal, that being said I have had to pull the toilet when there was no replacement seal available. I soaked the seal in a 10 % clorox/water solution and reinstalled, did not have any problem, but I was on the road and had no choice.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 07-25-2007, 07:34 PM   #14
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Go ahead and re-use the old seal...
Whats the worst thing that could happen ?
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
1960 toilet 60stradewind Sinks, Showers & Toilets 2 08-26-2002 10:34 PM
