Old 11-01-2011, 02:44 PM   #1
1969 27' Overlander
Tifton , Georgia
Need mixing valve
1970 Overlander, could be a 69 one. Shower mixing valve froze up , so we removed it. Need a replacement or some sort of water valve that will fit into that hole in the back side of the tub so that a flexable shower hose can be attached to it, or something l that will work. Thanks for any help offered.
G. Traveler is offline   Reply With Quote
Old 11-01-2011, 02:48 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Picture of original?
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
clancy_boy is offline   Reply With Quote
Old 11-01-2011, 02:48 PM   #3
Try Home Depot.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-01-2011, 03:08 PM   #4
. , At Large
It should be a Moen. You should be able to get a replacement either from Moen or almost any Airstream dealer.
Old 11-01-2011, 05:39 PM   #5
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
If it is Moen, and says that on it then they have a great service department and will assist you in every way.
Old 11-01-2011, 06:15 PM   #6
1969 27' Overlander
Tifton , Georgia
Thanks for all the quick responses. As you suggested, we did find parts to fix it a Home Depot.
Thetford waste valve replacement Safari64 Plumbing - Systems & Fixtures 6 02-24-2012 08:32 PM
City/water tank check valve gunner Classic Motorhomes 5 10-03-2011 06:49 AM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
