Old 06-18-2014, 06:39 PM   #15
jcain63's Avatar
1972 25' Tradewind
lancaster , California
Nice. I'm not installing a grey tank. I'd like too but can't really afford it right now and don't know where to put it without having to completely rebuild the rear frame. Were you able to keep the pocket door?
jcain63 is offline   Reply With Quote
Old 06-18-2014, 07:04 PM   #16
aquinob's Avatar
Portsmouth , Virginia
I kept the pocket door on mine, really just depends on where you position the shower base. The space for the door also has the vent stack so it serves a dual purpose.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 06-18-2014, 07:09 PM   #17
jcain63's Avatar
1972 25' Tradewind
Really? That'd be great. I really like the fact of having a door.
Old 06-18-2014, 07:13 PM   #18
jcain63's Avatar
1972 25' Tradewind
is there a way to install a grey tank without having to rebuild the entire frame. I only have the floor torn out from the back of the wheel wells to the back of the trailer.
Old 06-19-2014, 05:26 AM   #19
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Installing a gray tank doesn't involved modifying the frame, but it does involve a whole lot of everything else. I would suggest you don't need a gray tank if you always park in a campground where sewer connections are available. You can't dump gray water on the ground while boondocking.
This is a classic "while your at it" dilemma.
If your subfloor is out and the belly pan removed, installing waste water tanks is easier. My waste water tank project cost in the $1500 range for two tanks 500, freight 100, grommets, tank hangers, valves, ABS pipe and fittings 200, and a big tank cover 400. I also opted for a new SeeLevel tank water level monitor 230. And a whole lot of my labor, which is free according to my wife.
David
Name:	1404 Waste Tanks Installed.jpg
Old 06-19-2014, 04:21 PM   #20
aquinob's Avatar
There is always a way, just depends on how much money and time you want to invest. I thought about putting in a gray tank but when I pulled it all apart, I saw that the black tank was taking up most of the rearmost section of frame (on my '73 overlander). Given the time and cost issues, I decided not to even try and find a tank to install. I would have had to engineer the changes to the drainage and also install another valve to control dumping of that tank separately from the black. If you have most of the rear section of belly pan off, its probably not so bad in terms of access. Maybe someday I'll do it, but for now we have a blueboy and that hopefully will handle any time we dont have a hookup.
Old 03-07-2015, 08:29 PM   #21
1982 31' Excella
Hemingford , Nebraska
Our shower pan is also 24" square, but it appears the drain must be on the back side, toward the left. We have only found 24" pans with center drains or drains at the center of one side.
mwernke is offline   Reply With Quote
NEED HELP with my '72 TW wet bath jcain63 1970-79 Tradewind 3 06-11-2014 07:07 PM
Wet Bath Mirror pulled off wall-need repair ideas rmkrum General Repair Forum 6 08-14-2013 12:43 PM
How is it to live with a 'wet bath' ? darkStar Our Community 13 09-20-2011 05:17 AM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
wet bath - what years? AV8 1970-79 Tradewind 4 01-01-2004 07:16 PM
