Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-13-2009, 10:40 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Need help with Bravura Flange Seal
My Bravura toilet does not retain water in the bowl. I tried cleaning around the seal with a bent screwdriver, bent nail and coat hanger to no avail. I also used silicone and vaseline on the slide, but it still does not hold water. My question is, can I replace just the flange seal? and does that require removal of the toilet from the unit? Has anyone replaced this seal and where is the best source of supply. Thank you.
Steve
spat61 is offline   Reply With Quote
Old 10-13-2009, 11:15 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
This might get you started. Installation/parts manual link on the page.
Marksrv.com Thetford Bravura RV Toilet
Old 10-13-2009, 12:41 PM   #3
2002 30' Classic
Ocala , Florida
I had the same problem last winter. The fix is to pull the toilet and replace the gaskets. Thetford has a kit for replacing the gaskets. At the same time I replaced the flexible hoses that are part of the system. Be sure you use silicon grease on the gaskets. Do not use petroleum base. The kit includes the closet flange seal. Here is a link to the place where I bought the repair kit.
http://www.rvpartsoutlet.com/index.php?cPath=888_53
I also called Thetford and they were very helpful answering my questions.
Remember vaseline is petroleum base and accelerates the failure of the gaskets.
Bigdaddy_2 is offline   Reply With Quote
need closet flange seal for thetford drowe42 Sinks, Showers & Toilets 2 07-22-2009 09:16 AM
Thetford flange seal Chip Arnold Sinks, Showers & Toilets 2 01-06-2009 02:47 PM
Seal flange Siamese66 Sinks, Showers & Toilets 0 08-27-2006 10:06 AM
Bravura Toilet mtbob Sinks, Showers & Toilets 6 12-22-2002 02:19 PM
