Old 09-08-2014, 07:25 PM   #1
prairieville , Louisiana
Question Need Help please
We have a 1966 Airstream Trade Wind. I'm replacing all of the copper water lines with pex because the copper has more holes than swiss cheese. I've been able to disconnect the copper every where except for at the shower/sink.
This particular shower/sink is an all in one. My daughter was able to disconnect from the back of the sink but she was not able to get anywhere with the shower. Anyone ever run into this problem before?
I'll try to get some pics to post to give y'all a better idea. Not much room to work with from what she said and I'd rather NOT unrivet the sink and remove it unless absolutely necessary.
New Airstream Owner.
My66Dino is offline   Reply With Quote
Old 09-08-2014, 07:31 PM   #2
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
If I'm not mistaken your sinks overhangs the tub. What I have done in the past is cut an access hole underneath the sink and made a cover for it. It is not visible , but surely make any install and repair much easier.
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
submariner is offline   Reply With Quote
Old 09-08-2014, 07:38 PM   #3
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I had to remove the entire tub/ sink combo on my 65 overlander. Might be possible to accomplish this another way, but I doubt it! Have you inspected the floor under tub & toilet, etc? Chances are there is rot, unless you're very lucky! Removing the entire assembly is a major PITA! That's when the cash hemmoraging begins...
Cochese is offline   Reply With Quote
Old 09-08-2014, 08:16 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Cochese is probably correct about there being floor rot under the tub. My plywood is a bit soft there, but I sure am not going to remove the whole bathroom and the rest of the interior to fix this problem. It is just not worth it. Remember, new solutions have new problems.
I removed the tub/shower faucet and the sink faucet. The tub/shower faucet was a piece of cake; the sink faucet was a pita. See posts 37-40 and post 58 in the following link titled "Dan's 66 Tradewind Improvements".
http://www.airforums.com/forums/f116...nts-94152.html
I will try to take a photo tomorrow of the finished vanity, both from the top and underneath.
Good Luck, Dan
Old 09-08-2014, 09:57 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well, howdy Cou-San!
Welcome! You have great folks with great advice for you. Hope it clicks in soon!
Oh, we are picture freaks here if you can post some we would love to see how things are going!
Btw. If wood not totally ate up, you may be able to patch.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-09-2014, 07:28 PM   #6
Wasn't able to get pics yet but I am for certain that the floor and sub-floor is still good. We just tore up the old and put in new laminate and the PO used marine plywood and varnish in the rear access compartment which is where the swiss cheese copper pipe is. So, we aren't worried about under the shower. The problem we ran into is removing the copper from the back of the shower faucet. We got the sink detached easy but the shower did not move at all. My daughter even took off the front knobs. I'll see about getting pics tomorrow. I like your idea of going with LEDs. Much easier and it will be less drain on the battery.
Thanks, Dan. I like your ideas. It's always a great help when someone else has already gone thru the experience.
Old 09-09-2014, 08:18 PM   #7
submariner's Avatar
1948 22' Liner
1989 34' Limited
though i share some photo. the below shows , how my bath turned out, after replacing the faucets and changing everything to pex .
ID:	221380   Click image for larger version
Stefan
Old 09-09-2014, 08:26 PM   #8
submariner's Avatar
1948 22' Liner
1989 34' Limited
here some pix of the plumbing for the water heater and the toilet i did.
the water heater has a by pass, in case you want to shut it off.
as for the plumbing to your bath room faucets, I removed the sink and then added the access hole as mention earlier, so i can easy get to any possible future leaks..
hope that helps some
ID:	221382   Click image for larger version
Stefan
Old 09-09-2014, 08:47 PM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Stefan
Wow! Spectacular work on your bathroom. I wish mine looked that good. What did you use to refinish the sink?
Nice job on the pex plumbing work in the rear hatch also. Is that floor tile or vinyl covering the wood?
Dan
Old 09-09-2014, 09:19 PM   #10
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Stefan
Looks like you still have the original univolt (battery boiler). I replaced mine with a Progressive Dynamics 9245 (?). It is much smaller and lighter and does a nice job of charging my two golf cart batteries.
Dan
Old 09-09-2014, 09:41 PM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I forgot the photo.
Old 09-10-2014, 07:47 PM   #12
submariner's Avatar
1948 22' Liner
1989 34' Limited
The uniVolt I had was still in a good condition and I did not see a reason to replace it. As for the tile, I used commercial grade vinyl tile to match the rest of the original tile . Only the tile in the very back got replaced after I pulled the toilet to rebuild it .
Stefan
Old 09-10-2014, 08:05 PM   #13
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
66Dino
Here are photos of the sink with new faucets and a new drain, and also some photos showing the access hole in the bottom of the sink and plumbing connections under the sink.
Dan
ID:	221458   Click image for larger version
ID:	221460   Click image for larger version
Old 09-10-2014, 08:05 PM   #14
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
Originally Posted by TouringDan View Post
Stefan
Dan
X2!
Gorgeous tub and lav--what did you refinish with?
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
New and need help. Please! 72airstream Electrical - Systems, Generators, Batteries & Solar 4 05-28-2006 03:42 PM
Need Help Choosing Trailer Please! tallone Member Introductions 22 01-23-2006 08:54 PM
Need Photo Help Please!! KY Girl Forum Admin, News and Member Account Info 9 05-03-2005 01:07 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
