Old 09-11-2014, 04:37 AM   #15
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
We had the bathroom partially disassembled and had a friend paint it.. Not quiet sure what brand of paint he used, but it was made for plastics
As for the access hole, this was similar to what I did, except I cut 4 corner holes with a 2" hole saw and then cut it out. I need up making an access plate for it. Unfortunately do not have any pic.
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
submariner is offline   Reply With Quote
Old 09-11-2014, 05:37 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
On my 75 access is different, and possibly my copper was slightly less damaged, but on a couple of fixtures I left a foot or so of the original copper in place and flared the pipe to accept fitting to adapt to PEX.
I did this for ease of installation, made possible by this last foot or so of copper near the fixture valves having not been frozen before.
Old 09-11-2014, 06:12 AM   #17
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Both in same access hole under sink
Originally Posted by My66Dino View Post
We have a 1966 Airstream Trade Wind. I'm replacing all of the copper water lines with pex because the copper has more holes than swiss cheese. I've been able to disconnect the copper every where except for at the shower/sink.
This particular shower/sink is an all in one. My daughter was able to disconnect from the back of the sink but she was not able to get anywhere with the shower. Anyone ever run into this problem before?
I'll try to get some pics to post to give y'all a better idea. Not much room to work with from what she said and I'd rather NOT unrivet the sink and remove it unless absolutely necessary.
New Airstream Owner.
Don't know if your Tradewind is the same as our '66 Safari--rear bath with sink overhanging the tub. If so, access to the fittings for the shower are through the same access hole under the sink as those for the sink.
You have to be on your back in the tub with your head under the sink to get there. I find that a small crescent wrench with wide jaws is the most useful tool in that area.
Good luck!
Old 09-11-2014, 08:25 AM   #18
Zil
Curtis Wright
Eyren Haven , South Jersey
I had a similar problem. Solved by leaving a "tail" of copper and a shark bite pex to copper. Just put the fitting on the pex and pushed the end onto the copper.
Zil is offline   Reply With Quote
Old 10-10-2014, 04:00 PM   #19
prairieville , Louisiana
Finally got pics and a handy tool
Finally got pics of underneath and behind both the shower and sink facets. Also, bought a long handle tool specifically for facets. I'm hoping this will help since the wife wants to replace the sink facet and I'm not ready to cut it off in fear of doing damage to the fiberglass sink.
My daughter took all the pictures and it is viewable to the public.
https://www.facebook.com/media/set/?...1&l=5b3a81522d
My66Dino is offline   Reply With Quote
Old 10-11-2014, 08:48 PM   #20
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Let us know how this works, please.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-11-2014, 10:53 PM   #21
batman's Avatar
1964 22' Safari
modesto , California
Dino, If you can feel it, you can remove it. I did the same thing on my 64 Safari. I think home depot or Lowe's have swivel angled ratcheting end wrenches, cheep. I had mine out so it was easier for me to do. While it was out I had all of my pieces gel-coated white. However you can take them out in place. You just need to be a bit of a contortionist with the right tool. Take the nuts off the back of both faucets. Done. LOL, if you think getting the old ones off is bad wait until you put the new ones on. Just Kidding.
batman is offline   Reply With Quote
Old 10-21-2014, 12:19 PM   #22
Smile DONE finally
Thanks to you guys for all of the advice and my daughter who can fit into tiny spaces. We were able to get all of the copper tubing out and detached. She was able to cut the copper at back of the shower faucet and then slip a box wrench on the back and take them off. She was also able to get the cold water detached at the back of the kitchen sink. Now we have reinforced braided connectors on all faucets and ready to attache to PEX.
We also bought a new water pump since we were redoing the plumbing.
Thanks again guys.
Old 03-21-2019, 12:13 PM   #23
Tabasco's Avatar
1964 24' Tradewind
Stillwater , Oklahoma
Batman, we had to cut off our bench just like that when we did a new toilet in our 64 Tradewind. Would love to see what this looks like finished. We are trying to decide how to cover up the side of the tub and the plumbing lines that run behind the toilet and we need some inspiration!
Thanks in advance. Feel free to PM me, i know this thread is super old, but I'm digging hard for ideas!
Tabasco is offline   Reply With Quote
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
New and need help. Please! 72airstream Electrical - Systems, Generators, Batteries & Solar 4 05-28-2006 03:42 PM
Need Help Choosing Trailer Please! tallone Member Introductions 22 01-23-2006 08:54 PM
Need Photo Help Please!! KY Girl Forum Admin, News and Member Account Info 9 05-03-2005 01:07 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
