Old 01-17-2014, 01:12 PM   #1
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Need help
What is the distance from the wall to the toilet flange?
I rearranged the floor plan from a rear bath to a center bath. I'm putting in new tanks and don't want to cut a flange in the wrong place
Help is very appreciated.
rugjenkins is offline   Reply With Quote
Old 01-17-2014, 06:43 PM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I can go measure in our 86 and 89 excellas if that would help, but they're a different era from yours. Let me know if it would help!
Skatiero is offline   Reply With Quote
Old 01-17-2014, 07:50 PM   #3
rugjenkins's Avatar
1975 Argosy 28
That would be great. Since its a new overhaul with new tanks it will probably be the same. I'm getting a new toilet also.
Matt
Old 01-17-2014, 08:32 PM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Install Drawings usually come in the box with new toilet. Gets tricky when toilet is at an angle to the wall for clearance for the knees.....
Old 01-18-2014, 06:49 AM   #5
switz's Avatar
2014 31' Classic
Images: 8
Also check the toilet company website as that installation information is usually there as well.
Old 01-18-2014, 08:17 AM   #6
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
From the outside wall in the center bath, the CENTER or the toilet flange is 27". From the wall behind it is 11.5", and from the interior wall (where the door to the bathroom is, the hall wall) to the center of the flange is 12". These measurements are from our 86 since the toilet and vanity are currently out.
Old 01-18-2014, 10:11 AM   #7
rugjenkins's Avatar
1975 Argosy 28
Which wall does the back of the toilet rest? Is it the 11.5 measurement?
Thank you
Matt
Old 01-18-2014, 12:08 PM   #8
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Yes.
Old 01-19-2014, 09:42 PM   #9
rugjenkins's Avatar
1975 Argosy 28
Your a big help. Thanks. Now I can make the tank frames on the trailer.
Matt
Old 01-20-2014, 08:28 AM   #10
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Great! We are putting our bathroom back together this week.
Old 01-20-2014, 08:47 AM   #11
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Before you cut decide which toilet you wish to use as there are differences in size. The manuf. usually has diagrams on their web site.
jkcru is offline   Reply With Quote
Old 01-20-2014, 09:20 AM   #12
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Where you have the toilet matters.....watch the wall curvature so the lid and your "lid" will clear the wall/ceiling.
Old 01-21-2014, 10:06 PM   #13
rugjenkins's Avatar
1975 Argosy 28
Great advice. I've moved the floorplan from a rear bath to center bath. The tanks are being moved near/ under the axles. The sink/counter will be over the wheel wells and the toilet next to the wall closest to the center of the trailer. I'll research toilets for the one we most like. Suggestions on a awesome toilet?
I'll try and post the layout of the floorplan.Click image for larger version
Name:	ImageUploadedByAirstream Forums1390367156.182281.jpg
Matt
Old 01-21-2014, 10:15 PM   #14
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Try one of those taller porcelain bowl designs. They look a whole lot better than plastic and are much easier to keep clean. I installed the Dometic 310 and the spouse loves it. If you have the room for the oval bowl and prefer a wood seat - consider the 320.
SeeMore is online now   Reply With Quote
