Old 05-28-2011, 10:24 AM   #1
funhouse's Avatar
2018 23' International
1965 17' Caravel
La La Land , Wisconsin
Need Caravel closet pics.........
Thanks in advance for all the help we've received on this forum! We are installing the black tank in our '65 Caravel and aren't sure about it sticking out into the closet. We are also wondering about the pipes that run to the vent. I've heard some people are using a flexible hose to connect the tank to the outside vent. Show us your closet so we have a better idea of how it should look.
funhouse is offline   Reply With Quote
Old 05-28-2011, 12:19 PM   #2
cojer's Avatar
1966 17' Caravel
salida , Colorado
is this what you're after?
Name:	as closet 001.jpg
ID:	130889   Click image for larger version
Name:	as closet 002.jpg
Name:	as closet 003.jpg
cojer is offline   Reply With Quote
Old 05-29-2011, 07:07 AM   #3
funhouse's Avatar
1965 17' Caravel
Yes, that's part of it, but I'm wondering how it's vented out the roof also. Does the toilet tank always stick out into the closet? Thanks for your help!
Old 05-29-2011, 08:19 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
1966 Caravel cedar closet
I replaced the tank and fought the placement problems too. I had a new tank and was able to place the flange outlet where I needed it...and was then able to put the entire tank under the floor where it should have been. It is just plain sloppy Airstream design that put the flanges "close " to where they could be used.
Name:	AC power closet.jpg
ID:	130982   Click image for larger version
Name:	Caravel closet.jpg
Old 05-30-2011, 06:08 AM   #5
cojer's Avatar
1966 17' Caravel
salida , Colorado
here's what mine looks like
ID:	131070   Click image for larger version
ID:	131072   Click image for larger version
Name:	as closet 004.jpg
Old 05-30-2011, 06:16 AM   #6
cojer's Avatar
1966 17' Caravel
salida , Colorado
sorry i can do that better....here ya go
Name:	as closet 006.jpg
ID:	131074   Click image for larger version
Name:	as closet 007.jpg
Name:	as closet 008.jpg
ID:	131076   Click image for larger version
Name:	as closet 009.jpg
Old 05-30-2011, 06:29 AM   #7
funhouse's Avatar
1965 17' Caravel
Thanks! That's just what we needed
caravel
'67 Caravel Door lock Question vonzellen Doors & Locks 14 11-29-2011 01:26 PM
4CU 004 : Spring break at the lake silverback WBCCI Rallies & Events 68 04-19-2011 08:55 PM
New Electric - All in One, with Pics robwok Batteries, Univolts, Converters & Inverters 1 03-30-2011 03:27 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 07:25 AM
