Old 07-31-2005, 02:36 AM   #1
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Need a good source for SeaLand/Mansfield parts
I am in need of some info here. It seems like I may be missing a piece on the bottom of my toilet. I went to put my Mansfield 910 back in 2k5 today and when I put the new flange up to the bottom there doesn't seem to be any real place for it to seal to. When I took it off 3 months ago there was copious amounts of silicone under there. I could just put a bunch of silicone back under there but it seems kinda funky. Is that all there is or am I missing something here ? It seems like there ought to be a rubber gasket of some kind under there. I did a search here and came up empty handed. I'll include a pic. I did find an exploded view on the net, and from what I can tell I may be missing two pieces. It is hard to tell from the view I found, however. I would rather not replace the whole toilet as this one works fine. I am thinkin if I put it down like it is I will have some leaks for sure. Thanks in advance for the info.
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 07-31-2005, 10:47 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Chris, Sealand parts are not easy to come by... You need a floor flange seal kit. I found mine at a local RV place. You will probably need a new water valve too. I did. Look here for a good picture. http://www.sealandsanitation.com/vacuflush_parts.htm scroll down a little. Hope this helps Lee
silverleeper is offline   Reply With Quote
Old 07-31-2005, 10:55 AM   #3
Exeter , Rhode Island
I just replaced the floor flange seal and the bowl seals in my SeaLand toilet. A local RV dealer had the floor flange seal in stock. He ordered the bowl seals for me. Took two days to get them.
Ben
Rob30044 is offline   Reply With Quote
Old 07-31-2005, 11:14 AM   #4
wascobob's Avatar
wasco , Oregon
CHRIS TRY THIS---www.marksrv.com. Go to index and then to toilets. Has blowups for Sealand/Mansfield. More than one model. This might be what you are looking for.
Bob of Bob and Molly
PS Honk when you drive by the shop, or stop and say hi if you have time!
See you at Beverly Beach.
1988 Classic 290 motorhome
wascobob is offline   Reply With Quote
Old 07-31-2005, 11:23 AM   #5
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Try www.sealandtechnology.com and www.pplmotorhomes.com - they have a good library of tech specs for sealand parts and fast service.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-31-2005, 11:29 AM   #6
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Thanks all ! I will give the local RV dealer a call and see what they can do for me. Maybe I will get lucky and they will have everything I need.
I thought I was missing some pieces .
Bob, Marks RV is the site that I found the view I was talking about. It was good, could have been a little bigger ( easier to see ). One of these days when I am over your way I hope to have enough time to stop by. I did give a honk as I went by last Tuesday !
Chris
Project 2k5
Good 'Ole Glycerin for tire dressing JodynJeep Tires 10 01-25-2006 08:54 PM
The good and bad TRAPEZE Airstream Motorhome Forums 1 01-01-2003 07:21 AM
Confusion-1957 bubble parts smallfry General Interior Topics 5 11-21-2002 06:09 AM
source for high-end linoleum? Dave Cole Floor Finishes 3 10-02-2002 03:29 PM
Good campground in Omaha NE area? 83Excella On The Road... 0 07-24-2002 10:01 PM
