Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-30-2012, 10:48 AM   #1
Brow324's Avatar
2007 27' Safari FB SE
Scurry , Texas
Need a better fresh water line seal at Toilet
I have been using white PTFE tape on the threads of the fresh water line connection to the toilet in our Safari and cannot stop the darned thing from leaking. The problem is that it is nearly impossible to get fingers back there at an angle that allows for a good wrap around the threads and the tape keeps bunching up into a narrow thread instead of wrapping flat around the threads. So I am looking for an alternative to the white tape and am now considering trying good old plumbers pipe dope. Am working with standard RV type plastic connectors, of course. Any reason NOT to try pipe dope?
Would appreciate your thoughts and suggestions.
thanks
'07 27 FB - H.A.
Brow324 is offline   Reply With Quote
Old 10-30-2012, 10:52 AM   #2
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
I've switched almost entirely to the white pipe dope. Get a brand that is approved for both water and LPG to get the most use out of it. They'll sell you a relatively small jar of it, which will be enough for a lifetime.
Lynn
ACI Big Red Number 21043
eubank is offline   Reply With Quote
Old 10-30-2012, 11:02 AM   #3
Brow324's Avatar
Scurry , Texas
Lynn
There is a plumbing supply place near us, not a big box store but a small
store that the pro's use. They also sell gas piping....They'd most likely have it. Thanks!
'07 27 FB - H.A.
Old 10-30-2012, 11:49 AM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I just replaced the water line to the toilet. Pretty much the only way was to remove the toilet, hook up the water line, and replace the toilet. Four bolts and you're done.
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
drboyd is offline   Reply With Quote
Old 10-30-2012, 12:01 PM   #5
Brow324's Avatar
Scurry , Texas
Does the toilet go back down with a wax ring? I might end up doing that, it's so difficult to get to the line connection back there.
'07 27 FB - H.A.
Old 10-30-2012, 02:11 PM   #6
Central , Mississippi
On mine, it's a pseudo-compression fitting that doesn't use tape. In fact, the tape could keep my fitting from tightening the two faces together.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
HiHoAgRV is offline   Reply With Quote
Old 10-30-2012, 03:08 PM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Try TFE liquid. Available at every auto store.
AtomicNo13 is offline   Reply With Quote
Old 10-30-2012, 05:50 PM   #8
A W Warn's Avatar
2000 25' Safari
Mine takes a doughnut size plastic/foam ring.
Alan
Old 10-30-2012, 06:40 PM   #9
drboyd's Avatar
1978 25' Tradewind
Mine's just got some kind of a rubber gasket.
Old 10-30-2012, 08:24 PM   #10
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Do not use anything on the threaded joint. Go to a Home Depot and purchase a new fitting. It is a 1/2 inch PEX to female pipe adapter. Take the cone shaped washer out and replace the one in your fitting. Then just a 1/4 turn past hand tight will fix the problem.
Or cut yours off with a garden pruner and couple the new one on. You can buy Shark Bite PEX Rings that don't need special tools to close. Just use a pair of side cutters to close the ring. A 4 foot piece of 1/2 inch PEX is about $1.50.
Bigventure is offline   Reply With Quote
