Old 02-26-2019, 05:58 AM   #1
Magnet18's Avatar
Churubusco , Indiana
Natures head with urine diversion install: 310 motorhome
Posting up my install in pictures here
Guess I didn't get a good "before" picture that I can find, first picture is the old toilet and false floor/wall removed, showing the black tank (it sits half above and half below the floor)
Second picture is the black tank after modification
Third picture is a close up of the plug, I drilled a hole sized so the pipe fitting would thread in, then sealed with 3m marine epoxy (I am not a plumber, open to suggestions)
And the new false floor
ID:	334466   Click image for larger version
ID:	334468   Click image for larger version
Magnet18 is offline   Reply With Quote
Old 02-26-2019, 06:04 AM   #2
Magnet18's Avatar
More marine epoxy (I am not a plumber)
Mostly finished with the construction, still finishing work to do. Need to spend a day with the sheet metal tools, and a flooring install if the whole airstream is planned
The vent pipe for the black tank needs extended, will be doing that plumbing as part of the washer dryer install
ID:	334470   Click image for larger version
Old 02-26-2019, 07:52 AM   #3
Magnet18's Avatar
I also replaced my dump valves and plumbing when doing this. A third twist-on dump valve at the outlet allows the tanks to be shared, since urine volume is small, effectively adding grey tank space
Old 04-05-2019, 07:04 AM   #4
Magnet18's Avatar
Another finishing touch, a support bracket to help stabilize things now that the front bucket is gone
Highly recommended, as without the bucket it was a bit wobbly
1983 Airstream 310 Class A Motorhome
-Rob
Old 04-07-2019, 11:30 AM   #5
Sometime , Alabama
Thank You!
Magnet18...
...THANKS so much for posting this project!!!!
I'm going to be doing something very similar to your set up.
Your pictures were very helpful.
bigcountry is offline   Reply With Quote
Old 04-08-2019, 07:38 AM   #6
Magnet18's Avatar
Originally Posted by bigcountry View Post
Magnet18...
Glad it was helpful, that was my hope!
Old 04-08-2019, 08:01 AM   #7
Peoria , Arizona
Nice install. Another option for bracing if you want a facia covering the diverter tubing is to reverse the urine bin. A little more tricky to reach the lever valve if using one although there is a gap you can see to reach underneath. I used a furniture leg under the upside down urine holder for additional front support.
'15 RAM 2500 CTD CC 4x4 Outdoorsman 6.4 Bed w/Rambox & Titan Spare Tire Fuel Tank (30G), 2018 FC 28W (Queen) Landmark Truffle, ProPride Hitch
kb7our is offline   Reply With Quote
Old 04-08-2019, 11:25 AM   #8
Magnet18's Avatar
Simple and it looks good!
I still plan to install the bucket upside down for looks, though I wasn't sure how well it would support so i went with the total overkill bracket
Old 04-10-2019, 07:09 AM   #9
Peoria , Arizona
You'll have a very secure setup for sure!
Natures Head Composting Toilet Installation in 19' FC BoscoMN Sinks, Showers & Toilets 7 09-26-2016 05:37 AM
Composting toilets: Natures Head or Airhead? andreasduess LP Gas, Piping, Tanks & Regulators 18 11-19-2015 07:59 PM
Natures Head power requirement steveirving Waste Systems, Tanks & Totes 12 11-14-2015 03:37 PM
Natures Head Power and Venting steveirving General Repair Forum 4 02-18-2013 12:14 PM
