Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 02-17-2019, 04:20 PM   #21
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I have had the NH for the past 5 months - so I'm still finding out new things to watch out for. My install was also a modification from the norm in that we pipe the urine back into the black tank, which is merged with the gray for a total capacity of 65 gallons. Hence I don't have to deal with a 2-gallon bottle of urine every 2 days or so.
The fresh water supply (55gallons) last a lot longer as none of it is being used to flush the waste. I carry a couple of 5-gallon plastic jugs which I fill with fresh water whenever I find a spigot of potable water. Using a 4-foot aluminum step ladder, I perch a full 5-gallon jug on top of the ladder, then attach a short hose from the jug into the fresh water fill and let gravity do its job.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 02-19-2019, 06:34 PM   #22
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
I have thought about piping the urine tank into the black tank but could not figure out a foolproof way to keep the black tank smell from coming back into the urine tank. How did you plumb this?
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 02-19-2019, 07:01 PM   #23
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
I don't have a NH toilet and don't know what I'm talking about.
Seems to me if I was plumbing a sewer line to a sewer holding tank, I would incorporate a trap in the line, even if it was a 3/4" hose. Just a little sideways "S" in the line somewhere. That would seal off fumes from the tank to the NH canister.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 02-20-2019, 08:02 AM   #24
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The urine is piped directly down without any trap using 3/8-inch plastic pipe. There is a horizonal "S" in the line, as it needs to flow through the plug placed in the waste pipe from the original toilet (which is otherwise sealed). There is no discernable odor because the fan draws air out of the NH (including both the bin and the bowl when the cover is closed).
The keys to the success in using the NH is to make sure that:
1 - the coconut coir is barely moistened (too wet will create issues)
2 - there is air flow through the NH with the fan and exhaust tubing as the composting function produces moisture
3 - make absolutely sure that urine does not enter the solids bin
VE3JDZ
AIR 12148
WBCCI 8080
Natures Head Composting Toilet Installation in 19' FC BoscoMN Sinks, Showers & Toilets 7 09-26-2016 05:37 AM
Composting toilets: Natures Head or Airhead? andreasduess LP Gas, Piping, Tanks & Regulators 18 11-19-2015 07:59 PM
Natures Head power requirement steveirving Waste Systems, Tanks & Totes 12 11-14-2015 03:37 PM
Natures Head Power and Venting steveirving General Repair Forum 4 02-18-2013 12:14 PM
