Old 05-06-2014, 11:16 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Mystery leak
Under my 1964 Bambi 2 is a cylindrical protrusion under shower area that leaks a bit. Is there a p trap between shower and sewer connection? Hate to tear into the underside if I do not need to...
BambiTex is offline   Reply With Quote
Old 05-06-2014, 11:29 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Yes, you are probably looking at a cover for the p-trap.
Old 05-07-2014, 07:40 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Sure enough. Removing the insulated cover revealed a short brass p trap with a crack in it.
Old 05-07-2014, 08:07 AM   #4
Belegedhel's Avatar
Houston , Texas
brass... huh.
Old 05-08-2014, 05:24 AM   #5
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Call threeg salmon asian shows it to be copper
Old 05-08-2014, 06:03 AM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Closer examination :-)
Old 05-08-2014, 06:04 AM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
So far I have not gotten plastic replacement trap to fit :-(
Old 05-08-2014, 07:07 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You might be able to have the copper piece soldered. It would fit right back where it is.
Old 05-08-2014, 08:18 AM   #9
1977 Argosy 24
Milltown , Wisconsin
Must have frozen at some time. Clean it up and solder like J. Morgan said would be the easiest fix.
ventport is offline   Reply With Quote
Annoying Mystery Leak rc707 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 18 05-28-2010 07:35 PM
Mystery Leak moosetags Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 07-08-2007 05:38 AM
Water leak mystery... TennisMan 2007 Safari SE 1 06-03-2007 06:40 PM
Mystery Leak Excellaphant 1987 - 1989 Excella 10 12-21-2005 08:57 AM
Mystery coolant leak PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 11 06-06-2005 11:34 PM
