Old 11-05-2013, 08:27 AM   #1
rogerdodger's Avatar
Fresno/Clovis , California
My Toilet wobbles, whats the fix?
My Argosy toilet has the above floor tank, and the toilet mounted to it. There is only some thin cardboard between tank and toilet which does not support it. How did you fix yours?
Roger
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 11-05-2013, 10:44 AM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Build a plywood 'porch' for the toilet. A cleat on the wall for support there and a plywood piece in front for support. Having the toilet rest on the black tank will break the black tank top sooner or later. The closet flange rests on the plywood and the toilet bolts to the flange.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 11-05-2013, 11:11 AM   #3
That sounds good, what thickness of plywood? I am installing a new low boy toilet which is going to create other issues regarding rear wall clearance, so I will rebuild the area.
Thank you, Roger
Roger
Air# 29488
Old 11-05-2013, 11:17 AM   #4
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
How much do you weigh?
For a supersized, grain-fed, owner or guest on a high-fiber diet, I would use 3/4 for a firm ride.
But you can get by with 1/2.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-05-2013, 11:39 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
3/4" Front, Back, Top and end.
Old 11-05-2013, 05:13 PM   #6
Ok, thanks for the help. I am going to remove the thin paneling that runs from tub to under the cabinet, then install one piece of 3/4 plywood from tub to cabinet, and use cabinet shelf for cabinet floor. I just need to figure out where to place the hole for the flange.
Roger
Air# 29488
Old 11-05-2013, 06:12 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I used the original board for a template.
By the way. The toilet flange screws into the top of the tank. You will need some kind of spanner wrench to remove. I made my own.
I built a box on all sides of the tank and under the vanity out of 3/4" plywood. Very sturdy.
Old 11-05-2013, 06:38 PM   #8
I looked at the picture of your bath, looks good. Does the toilet touch the shelf at the top, or did you have to trim the shelf?
Roger
Air# 29488
Old 11-05-2013, 07:29 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The toilet is Aqua 5. It does not touch the "secret" compartment above and behind the toilet.
I did remove the door to that compartment, because it was padded, the toilet lid would not stay up. Not a big deal. That compartment doesn't have room for much.
