Old 02-26-2011, 05:06 PM   #1
1977 Argosy Minuet 6.0 Metre
deland , Florida
mounting toilet flange on black tank
so ive been googling for over a hour and cant seen to get my answer. i am doing a custom wet bath in my safari. only cause we normaly stay where there are baths and we would prob only use the as bathroom 1 time a year. anyway ive got everythign planed and mapped out and found a black tank that will fit the space i need. it has no holes drilled in the top for the vent or toilet. it is the plastic style tank not fiberglass. my question is who can plastic weld ( or whtever its called) the flange on the tank for the toilet or can this be done by me with some epoxies?
386kustoms is offline   Reply With Quote
Old 02-26-2011, 05:47 PM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
If it's ABS plastic you could do it yourself.
SilverHoot is offline   Reply With Quote
Old 02-26-2011, 05:58 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Let your fingers do the walking...
We found a local company that makes tanks (fancier than ours) and they put the fittings in the tank for me. We just marked the tank where we wanted them and they did it. As I recall, it was about $20 including the flange....and I could watch!
They basically cut the hole with a hole saw, then put the fitting on the drill and spun it in the hole. The friction caused enough heat to fuse them together...pretty cool!
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 03-04-2011, 07:52 AM   #4
1966 20' Globetrotter
Killingworth , Connecticut
ABS you can solvent weld. White plastic you have to spin weld. Solvent weld is basically ABS shavings mixed with Acetone to make a paste. cut the hole, sit the flange in, apply the paste, let dry.
CtRobert is offline   Reply With Quote
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
New black tank pan RaleighAir Waste Systems, Tanks & Totes 21 02-24-2011 06:00 AM
Unable to dump black water tank before 20 deg. forecast mikeandnora Waste Systems, Tanks & Totes 3 02-04-2011 09:46 AM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 09:28 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
