Old 06-19-2016, 11:15 PM   #1
1968 26' Overlander
Missoula , Montana
Montana needs help draining
Hi Friends! We are the proud new owners of a 1968 Overlander 26T Airstream. We are now calling it our sole home for the next few months while our home is being built.
Question: we filled up our water tank to 1/2 full - when we do dishes in our kitchen sink the water backs up in the tub and toilet. What does this mean and what should we check? I can't imagine the holding tank is full after 5 days of doing light dish duty. Can you help?
sonyamontana is offline   Reply With Quote
Old 06-19-2016, 11:25 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings sonyamontana!
Welcome to the Forums and the world of Vintage Overlander ownership!
Unless your '68 Overlander has been modified from its original configuration, it does not have a gray water tank (where the drains for sinks and bathtub would empty), rather the coach was designed with the intent of draining gray water on the ground. My guess is that you have been filling the black tank with a mixture of toilet waste along with your gray water resulting in the backup that you mention. Thetford makes a termination cap for the dump valve that allows the gray water to be drained into a portable tank through a short length of garden hose (these tanks are often called a "blue boy") that can be emptied into an appropriate drain. If your coach has been modified and now has a gray water tank, it is entirely possible that you are completely filling the tank in the time frame that you mention as the gray water tanks that are often retrofitted into Vintage Airstreams are often quite small and need frequent dumping.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-10-2016, 05:26 PM   #3
1968 26' Overlander
Missoula , Montana
Kevin! Thank you so much! No grey water tank available but we did get a Thetford cap with a garden hose adapter which is a game changer. Really appreciate the help!
HELP!! House and chassis batteries draining! weirdstuff Sprinter and B-van Forum 105 04-18-2015 05:49 AM
grey water draining help needed dereks57 Waste Systems, Tanks & Totes 2 05-26-2013 08:26 PM
Draining eddo Fresh Water Systems 4 09-21-2005 08:28 PM
Electric water heater element: Draining dilema rfield54 Water Heaters, Filters & Pumps 4 05-19-2005 10:07 PM
Shakedown trip--holding tank draining quest. Kistler Our Community 6 12-01-2002 09:21 AM
