Old 05-23-2014, 07:48 PM   #1
2006 30' Classic
Milton , Florida
Moen PureTouch Galley Faucet
The galley faucet in our 2006 Classic has suddenly begun to shut itself off for any water demand setting other than fully open. Has anyone on the forum experienced this behavior? This is the single lever faucet with the built-in filter in the spigot.
I will call the Moen hotline after the Memorial Day weekend.
I removed the single lever handle, but did not see any obvious cause for this problem.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 05-23-2014, 09:01 PM   #2
SteveH's Avatar
Common Sense , Texas
I've had that problem, and with mine it was the screen thing just after where the flexible hose screws onto the spigot/handle. Trash comes out of the water heater after it has set dry for a while and clogs it up.
Regards,
Steve
Old 05-24-2014, 06:44 AM   #3
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
There is also a screen in the connection under the sink. We were having so many issues with ours that earlier this week I even disassembled the plastic manifold in the head of the handle to remove little bits if mineral buildup that had made their way inside. On the up side.... it was an hour well spent. Flowing like a champ now!
Sent from my XT1030 using Airstream Forums mobile app
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 05-24-2014, 06:49 PM   #4
2006 30' Classic
Milton , Florida
Under the Sink?
Are you talking about the connection under the sink? Did you have to go under the sink and unscrew the flexible hose fitting from the faucet assembly?
F. A. Meloy
2006 30' Classic
Old 05-24-2014, 06:54 PM   #5
SteveH's Avatar
Mine had a hand sprayer that actually came out of the faucet with a flexible hose attached to it, and it was at that junction. If yours does not have that feature, see if there is an airiator/filter that screws onto the outlet of the faucet.
Regards,
Steve
Old 05-24-2014, 07:12 PM   #6
2006 30' Classic
Milton , Florida
Hand Sprayer Location
Mine has a hand sprayer, but it does not come directly from the spigot. My hand sprayer connects to the assembly below the counter top. It sounds like we may have different models.
F. A. Meloy
2006 30' Classic
Old 10-27-2014, 07:15 AM   #7
OpenHigher's Avatar
2006 Safari SE
Los Alamitos , California
Hi. We have the 2006 Safari Moen kitchen faucet. The faucet has an internal filter with a button on front which when pushed reduces water flow to go through the filter hole. It will not release to allow water to exit the standard larger hole. Moen says it cannot be fixed, and is no longer made. Thoughts?
Robert
OpenHigher is offline   Reply With Quote
Loose Moen galley fixture Goal15 Sinks, Showers & Toilets 9 04-13-2012 12:36 PM
Moen Puretouch Galley Faucet BoJo Fresh Water Systems 5 03-01-2009 06:44 AM
'77 Moen faucet parts LI Pets Fresh Water Systems 6 12-18-2006 09:26 AM
2006 Classic Moen Faucet Filter Pappy Water Heaters, Filters & Pumps 18 10-02-2006 10:54 AM
Delta Faucet instead of the old Moen okay? 73ANDY Sinks, Showers & Toilets 7 05-01-2003 06:21 PM
