11-04-2006, 05:15 PM
1967 24' Tradewind
Alameda
marine lav: black tank away from toilet?
I have a question before we start building based on our current layout plans.
Trailer is gutted completely and we're starting anew.
We want to put a black tank somewhere other than where we plan to put the toilet. We intend to use a marine-style toilet that has a pump that will pump waste to where the black tank will go. As our plans are now, we can't put the black tank under the toilet, we have a double axle that prevents that.
I don't even know where to look for such a marine toilet but my husband says he's done this for houses and that he knows boaters use them. Any boaters out there have any input?
Has anyone done this or have any product recommendations?
If it isn't possible, we'll adjust our plans. This layout, with the bathroom on the streetside of the trailer, will allow us to put a bedroom in the back that will fit both of us.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
11-04-2006, 05:22 PM
2012 28' International
New Orleans
, Louisiana
West Marine, Defender, Boat US, JSI, Boaters World, that should give you a good start. You can get hand pumped marine toilet, electric marine toilet, anything you want.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
11-04-2006, 05:30 PM
1967 24' Tradewind
Alameda
I'm already looking at a site called "Lavac", seems like it's do-able...I'll check out the other sites too. Do you have any experience with this kind of installation? We don't, and I'm nervous about it. Once we go with this, it's a done deal because the entire layout depends on what we do with the bathroom. I hate to get into something that's nothing but problems...but if we do a good job installing it, and take into consideration all things.. considered, it should work OK. All input welcome, help me anticipate problems....the cost of a marine toilet is high but we'll pay it to be able to sleep in the same bed and not have to step over the sleeping person to get to the lav.
Thanks, keep 'em coming...
~ Hurley
ingrid
11-04-2006, 05:48 PM
New Orleans
, Louisiana
Not Hard
I have changed them out on my sailboats. On my boats they take suction on the sea and pump overboard or to a holding tank to be pumped out later. This is done with a Y valve. Do a little research on marine systems. Contact user Boatdoc as he was in marine repair for years. I think it would be simple and very easy. I am sure that marine toilets can be setup to use water supplied by a pressure system instead of a seawater suction. Pipe to your blackwater tank with hose and you are good to go. I see no problems.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
11-04-2006, 06:28 PM
1967 24' Tradewind
Alameda
I'm looking at toilets on the Jabsco site that say they need to be hooked up to a pressurized system requiring at least 3 1/2 GPM flow rate. Would it be possible to use the grey tank water as a source for this? Maybe a separate tank and pump needs to go in. I'll PM boatdoc...
here's the link to the toilet I'm looking at.
http://www.jabsco.com/prodInfoApp/se...I&typeId=JMTQF
~ Hurley
ingrid
11-04-2006, 06:38 PM
I think it would be better to use greywater. If you hook up to your freshwater you need lots of double check, reduced pressure, antisiphon backflow prevention.
11-04-2006, 06:41 PM
1967 24' Tradewind
Alameda
Yes, definitely grey water. Putting a toilet anywhere near a freshwater system is just asking for Trouble with a capital T. I'm looking at The Vap site and there's a 4.0 pump and also the Shurflo site has a 3.7 all purpose pump that I suppose we could use. We'd have to have the grey tank full to flush, but isn't that how it's done anyway?
~ Hurley
ingrid
11-04-2006, 07:07 PM
New Orleans
, Louisiana
AS Toilets Are Connected to the FW System
I think all current RV's have their toilets connected to the freshwater system as dose your home. Boats often use sea water for flushing and fire protection. It is hard to make fresh water at sea. Grey water will have to much trash in it to use for flushing. Toilets are designed not to have a cross connect as are your sinks, read air gap.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
11-04-2006, 11:54 PM
1967 24' Tradewind
Alameda
Gotcha. I just was informed of that from my husband also. I thought he had told me it was the grey tank that provided the water for flushing.
This looks like it's going to work out OK, but I have no idea where to start looking for actual products and still have so many question marks going around in my mind. I called The Vap and bravely asked this question on their voicemail, and I'm hoping to learn from them too, what our options are. We've got a long way before we start installing the toilet. Sure could use a source for prefab shower stall too. When we do this finally, I'll take pictures and put it on my progress thread.
~ Hurley
ingrid
11-05-2006, 06:09 AM
New Orleans
, Louisiana
thread.
You will have a hard time finding a Pre Fab shower stall for
a RV or a boat. The reason is that a boat and a AS share sides which
are not straight but curved. The Airstream is relative easy as Aluminum
channel is used to hold partitions to the side of the coach which is
much easier than tabbing in with fiberglass. You man be able to use a
removed partition for a pattern of the curve or learn how to use a
tic-stick to get the curve of the trailer. On my boat I covered the
interior of the wet bath with plastic sheeting to seal out the water.
You often see this material in the restrooms of fast food restaurants;
I used contact cement to attach. As for a shower pan you may have to
fabricate one, but I do think you could adapt a home unit or a RV unit
to your needs. I have viewed so many wonderful custom interiors of
Airstreams I think you will have great success. Look up Boat US or West
Marine and make a visit to their stores, one of the catalogs has all
the diagrams of the various systems, a boat and RV systems are
basically the same. Good Luck Jim
Jim N5TJZ Air# 174
2011 F150 Ecoboost
11-05-2006, 01:01 PM
Creampuff
2022 27' Flying Cloud
2016 25' International
Airstream - Other
Malibu
If you have the option to put the toilet on a raised platform so as to enable the 3.5" system (you would need at least 5" to allow elbows) to travel along the floor to enter the blacktank via it's top suface the you can use the conventional Sealand or similar toilet.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
11-05-2006, 02:39 PM
1973 31' Sovereign
Portland
I have been thinking of installing a mascerator pump on the output side of my holding tanks. I have the impression that some forms of marine toilet arrangements have a single mascerator pump that can be used for pumping from the toilet to the holding tank and for pumping from the holding tank to the outlet for dumping. Does anyone have any specific knowledge or experience they would like to share about that type of installation - if it is possible?
Malcolm
11-05-2006, 02:40 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
Our boat had an electric marine toilet that was plumbed as part of the fresh water system and did not use sea water. The holding tank was at least 10 ft from the toilet and worked just great. (Pulled about 20 amps)
Most RV toilets work on the gravity feed system with the black tank directly below the toilet.
I would think you could use the marine toilet and put the black tank just about anywhere as long as it is slightly below the toilet or you use a check valve if black tank is even with or higher than the toilet.
Garry
11-05-2006, 02:48 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
Malcom,
On our boat the Sealand head had a mascerator built in we used a large foot pump with a 2 or 3" line to pump out the black tank, worked much faster than using a mascerator pump.
Camping World sells a set up like you are asking about but I don't remember the name of it. Allows you to empty the black tank up hill or long distance to a home septic system.
Garry
11-05-2006, 03:15 PM
2004 30' Classic Slideout
Ft. Myers
Silvertwinkie--Wilcox Crittenden makes a santa cruz model with a macerator and wall switch, but draws 30 amps. Raritan makes the sea era electric toilet with a macerator that draws 18.0 amps. Retail these toilets are $549.00 and $464.00 respectively at West Marine. Find someone with a port supply account (wholesale) and you could probably lower the cost greatly. --Mark--
S/OS #045 2006 GMC Sierra 2500 Duramax w/ Hensley Hitch, 15" GY Endurances and Tire Minders
--Mark and June-- "Every time I feel the urge to exercise, I go lay down until it passes." Mark Twain
11-05-2006, 04:30 PM
New Orleans
, Louisiana
Malcolm
This is the easy way. Clear elbow with water fitting and quick disconnect discharge line. Use thickened epoxy to glue the pump to the elbow. I use this to pump out my tanks to my home cleanout which is 4 feet off the ground. It just fits where the hose attaches and I run it with a 20 amp battery charger. I have a extension which uses anderson power poles to connect to trailer battery if need when on the road.
Good Luck Jim
Jim N5TJZ Air# 174
2011 F150 Ecoboost
