Old 08-16-2010, 09:26 PM   #1
1997 30' Cutter Bus (Ford)
grosse pointe , Michigan
low water pressure
My water pressure is low and the water pump when activated goes on forever. I assume that I have a leak somewhere but can't find a water leak. What should I do?
JC
cutbrain is offline   Reply With Quote
Old 08-16-2010, 09:45 PM   #2
x
XXXX , XXXX
JC Do you have low pressure when hooked up to city water. If not then maybe the problem is the one way or check valve at the city water connection. It is meant to stop water from flowing back out of the coach when using the water pump. A few other spots to check are the pressure relief valve and the drain plug on the water heater. I'm not familiar with your unit but if you have low point drains to drain water out of the system to winterize they may be leaking out. Low point drains are usually located on the floor inside a cabinet and drain right outside on the ground. Check all these points because if you don't see water leaking inside youe unit it may be leaking outside. I hope this helps.
wasagachris is offline   Reply With Quote
Old 08-16-2010, 09:52 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Some systems have a tap you can open to fill your tank, when hooked to city water. If that tap is slightly open your pump will run with low pressure.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-16-2010, 09:55 PM   #4
x
XXXX , XXXX
Hi Doug Have you seen the pics of my tall boy. I'm thinking of installing a second floor! LOL
Low Water pressure in 98 classic gretchen Fresh Water Systems 4 07-07-2010 05:36 PM
Hot water pressure low connorsa Full-Timing 4 09-11-2009 01:11 PM
Looking for low water pressure diagnosis Dreamnair Sinks, Showers & Toilets 9 09-10-2009 11:10 PM
Low hot water pressure??? FBC72 Water Heaters, Filters & Pumps 2 07-29-2007 10:49 PM
low water pressure dikku Fresh Water Systems 7 07-26-2007 09:50 AM
