Old 09-11-2010, 09:16 PM   #1
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Low rpm, high hp 12v motor
I'm sure there is an electrical engineer or serious hobbyist who knows way more about this stuff than I do. Here's the situation. Our composting toilet is wider than I'd like. I've done a cut out on the wheel well to accommodate the manual "flapper" that seals the bowl from the composting compartment. There's also a lower handle for turning the compost located in a really lousy location... but fortunately, the handle comes right off and the rod has a threaded end. This would be perfect for a small pulley. So, thinking out loud I said, "Hey, if I could find a low rpm, high torque motor to turn a large pulley, I could probably get the right gearing to turn the compost without the handle."
The pulley would fit flush while the handle (and the human arm required to turn it) take up far more room. Besides, the compost is much more likely to get turned via a switch than by hand.
So, if someone has a decent idea of a motor I could use to experiment, I'm open to suggestions.
hampstead38 is offline   Reply With Quote
Old 09-11-2010, 09:41 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I don't have any specific recommendations, but you're in luck. What you really need is high torque, hp doesn't matter much for this application, and most electric motors make their max torque at 0 RPM.
Old 09-11-2010, 09:44 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
What about something like the motor on an electric tongue jack?
Richard
Old 09-11-2010, 09:46 PM   #4
1977 20' Argosy 20
san diego , California
Just happened to see this while browsing.
American Science & Surplus : Send to a Friend
Just a thought.
Keith
argy is offline   Reply With Quote
Old 09-11-2010, 09:52 PM   #5
richinny's Avatar
2011 34' Classic
i seem to recall something that might work in HVAC ducts. any hvac guys out there?
Ricky
Old 09-12-2010, 07:25 PM   #6
1967 26' Overlander
Upperco , Maryland
I wish I knew how to set up the pulleys without creating so much pressure that it will "egg" the opening for the crank. Nice thought on the motor. I'm thinking the key is lots of torque but a very slow turn.
Old 09-12-2010, 07:59 PM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Check these guys out. A geared motor may just do the trick.
MPJA - Power Supply, Power Supplies, Security Cameras, LCD, Fans, Etc.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-12-2010, 08:40 PM   #8
richinny's Avatar
2011 34' Classic
do you have enough room to put a double pulley on the crank and a tensioned idler pulley in the opposite direction?
Ricky
Old 09-12-2010, 09:02 PM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
You may find that the most inexpensive and practical approach is to obtain one or more power window motors from a junkyard, and adapt them.
Old 09-13-2010, 07:04 AM   #10
richinny's Avatar
2011 34' Classic
how about a wiper motor with the arm/crank on it?
Ricky
Old 09-20-2010, 10:28 AM   #11
DKB_SATX's Avatar
1976 Argosy 28
This motor is battery powered... you could either continue to use that (it claims 90 hours of use from a pair of D-cells) or you could convert it for 12V use. Should be high-torque, low-RPM and it would probably be easy to make a shaft adapter.
Auspit Australian Outdoor Rotisseries - "Low and Slow" BBQ at its finest!
Old 09-20-2010, 12:12 PM   #12
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
I think Jammer hit...a power window or wiper motor..enough torque there to move heavy snow from most windshields...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 09-20-2010, 01:22 PM   #13
Crusty's Avatar
1992 34' Excella
How about a starter motor from a small car engine or a motorcycle?
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 09-20-2010, 02:35 PM   #14
richinny's Avatar
2011 34' Classic
i think he wants to limit the power so that if the auger binds, it doesn't break it. i guess you could put a clutch setup in it such as used in a drill. come to think of it, a drill might be the total solution.
slinging poop at high speeds could be useful in other situations LOL.
Ricky
12v
Looking High and Low warpedw Member Introductions 1 01-16-2010 02:46 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
carrier v low cool vs high cool rvlover Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 08:20 PM
What is the correct RPM for 60 MPH? AccessMaster Airstream Motorhome Forums 9 12-31-2003 09:48 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
