Old 03-26-2012, 06:41 PM   #1
Goal15's Avatar
Dallas , Texas
Loose Moen galley fixture
The Moen faucet fixture in our 2006 Safari 23 has been loose ever since we got it. Not unworkably loose but annoyingly not tight. It's loose where the base of the fixture fits flush against the sink top.
I have included pics of the underside as well because I can find no discernible way to tighten this fixture. Hopefully someone out there has run into this or is a plumber who might be familiar with the type of clamp (at least I think it's a clamp) this is and how it is tightened.
D
ID:	154385   Click image for larger version
ID:	154387   Click image for larger version
Goal15 is offline   Reply With Quote
Old 03-26-2012, 06:57 PM   #2
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I specify single hole sink fixtures all the time, and some are tricky to keep tight. I found the instructions for this faucet on Moen
http://www.moen.com/shared/docs/inst...ts/ins106h.pdf
and it looks like the single brass nut is the thing that holds the C shaped clamp tight. You might want to get a knurled lock washer to put between the nut and the C clamp, to keep if from working loose on the road. Hope that helps
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-26-2012, 07:10 PM   #3
Goal15's Avatar
Dallas , Texas
Global:
Thanks for the quick response... the illustration is very helpful and now going back to my pics i see the brass nut... and it even looks loose in the photo... so i will try tightening it before i try the lock washer... i was trying to see if there wasn't either a screw or allen bolt in one of the smaller holds on the brass colored flat surface of the collar bracket.
for some reason that brass bolt just didn't look to me like it would have that function.
thanks again
Dana
Old 03-26-2012, 07:36 PM   #4
Globie64's Avatar
Images: 18
It's a small bolt to keep the large C clamp thing secured. The faucets I've had trouble with have been like that, the stronger ones (HansGrohe) have several nuts to spread out the force.
Glad if I was some help, it's great to be able to when it's something I can do in my sleep.
Globie.
Old 03-26-2012, 07:43 PM   #5
Goal15's Avatar
Dallas , Texas
Globie:
Guess i could at least get the name right....
believe it or not i actually have a basin wrench from back in day of old house restoration that may be just the thing to tighten that nut with... now to dig through the tools in the garage to find it. But im sure if i can't find it i can get a crescent on it
Thanks again
Dana
Old 03-26-2012, 07:48 PM   #6
Globie64's Avatar
Images: 18
hahaha- thanks. I totally understand, and all the best to you! I have all my old house restoration tools as well; my partner is a contractor and I keep the tools well hidden from his crew.
Old 03-26-2012, 08:08 PM   #7
Goal15's Avatar
Dallas , Texas
Small World
Tundra is my tow vehicle of choice as well.
Old 03-26-2012, 08:17 PM   #8
Globie64's Avatar
Images: 18
It's a good truck, and it's nice to have something that doesn't break down all the time!
Old 04-12-2012, 10:39 PM   #9
Goal15's Avatar
Dallas , Texas
Just to follow up.... and finish out this thread.... Thanks Globie... that brass nut was indeed the culprit... i was able to hand tighten it and pull the fixture tight to the sink top...
thanks again.
time to go camping!
Old 04-13-2012, 12:36 PM   #10
Globie64's Avatar
Images: 18
Hey, glad to be of help- it can be a pain to learn this stuff the first time, if it can be shared it makes it worth it
Loose Dinette Bench Seat Cold Beer Cabinets, Counter Tops & Furnishings 14 06-30-2017 04:24 PM
Replacing Moen Shower Valve Cartridge az-lh Sinks, Showers & Toilets 47 09-06-2016 02:35 PM
2011 International 25FB -- Freeze Damage to Shower Heads and Galley Faucets NJ2Cali Plumbing - Systems & Fixtures 10 02-01-2012 02:09 PM
Round galley sink samitch Sinks, Showers & Toilets 27 12-23-2011 06:38 AM
Bargman Tag Light Fixture and Parts lwebb Lights - Interior & Exterior 0 11-11-2011 04:22 PM
