Old 03-11-2013, 11:43 AM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Limited space. Sealand traveler or something else?
My Cayo C-11 has a wet bath with tight clearance. I want to replace the existing toilet, which isn't original and has a cracked valve.
I'd like to shoehorn in a low-profile Sealand Traveler but it looks like the flush pedal is going to hit the sink surround. Here's a photo of the layout, you can see the existing toilet on the right and the curve of the sink surround (which is removed in the photo).
I think there's a good chance that I'll have to trim the pedal to get the toilet to fit.
Is this still a good choice or should I be looking for something else? The only alternatives that lack a side pedal seem to be economy toilets, in which case I'm probably better off seeking out a new valve for the one I have.
Advice welcome
Old 03-11-2013, 03:49 PM   #2
The demensions for all the Dometic toilets are on their website. I know the Galaxies are small and might fit, but they are plastic. Perhaps one of the china toilets is small enough to fit.
handn is offline   Reply With Quote
Old 03-11-2013, 05:01 PM   #3
1988 32' Excella
Robbinsville , New Jersey
You should check on one with a hand flush.
