Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 10-11-2007, 12:58 PM   #1
tlavergne
tlavergne's Avatar
Profile:  1978 29' Ambassador
Kenton , Ohio
leaky showerhead - 1978 Ambassador
I have a 1978 Ambassador. The original shower head has been leaking when we push the button in to the off position while we are soaping up. I bought a new one from J/C and it does the same thing...it won't completely stop the flow. Are they suppossed to do that? Is it like a pressure relief thing? I would think it should stop the flow.
Tom
#8848
tlavergne is offline   Reply With Quote
Old 10-11-2007, 01:42 PM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Tom
#8848
Yup, that's what they do. I am not sure why, but they all dribble. I kind of like it because as I take quick showers (small grey tank) I use the dribble to help lather up. Maybe someone else can tell us the real reason they are designed to do this....
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-11-2007, 01:49 PM   #3
Gunnyusmc
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Showerhead
This is in the desigh to prevent 160 degree water from hitting you when you turn it back on.
The new water heaters are set at 160 degree and are not adjustible.
If the showerhead shut off completly the hot water would rise too the top resulting in someone getting burned.
Gunny
Gunnyusmc is offline   Reply With Quote
Old 10-12-2007, 08:36 PM   #4
tlavergne
tlavergne's Avatar
Kenton , Ohio
Gunny,
Makes sense...thanks.
Tom
Old 10-12-2007, 10:12 PM   #5
Kevbo10
Profile:  2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Tom
#8848
my vintage '05 does the exact same thing. i also use it to "lather up". if one was to say use the SEARCH function up on the top right, bet you could find a gang of threads on this very issue...
just sayin',
jackson
Kevbo10 is offline   Reply With Quote
Old 10-13-2007, 06:31 AM   #6
SilverCottage
SilverCottage's Avatar
Profile:  2007 27' Safari FB SE
LONDON , ON
The dribble is to remind you that the water to the shower is still on and to use the wall mounted temperature control ON-OFF knob to turn off the water (which provides a much better seal) than anything in the shower head could.
I also find it gives enough water to lather up so I don't really mind it.
SilverCottage is offline   Reply With Quote
Leaky Airstream Crawdad Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 09-23-2007 11:04 AM
Leaky rivets? wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 04-07-2006 12:16 PM
Leaky Excella Steve Heywood 1997 -2001 Excella 13 02-19-2006 02:35 PM
leaky used 04 28 ccd annw Our Community 16 01-20-2006 09:40 PM
leaky sewer? John Greenlee Waste Systems, Tanks & Totes 5 12-31-2005 05:26 PM
