Old 06-06-2008, 10:47 PM   #1
2008 16' Safari
Anaheim , California
? Leaking shower cubicle
Hi there all,
I bought my 17' Safari Sport Last year in November (new) and the last few trips have noticed that there is some water accumulating where the floor meets the wood below the entrance to the shower cubicle. Its a plastic accordian shower "door". I'm not sure where the water is coming from as the shower door/ partition is securely closed when anyone is using the shower.Any ideas? I'm concerned as I dont want the wood partitions to start rotting or any damage to be done to the floor. I'm thinking about taking it in to the Airstream specialists locally here in Bellflower ,CA.
Any advice would be most appreciated.
AirStrmFltRN is offline   Reply With Quote
Old 06-06-2008, 11:04 PM   #2
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
This might be helpful:http://www.airforums.com/forums/f396...tml#post327271
SilverGate is offline   Reply With Quote
Old 06-07-2008, 04:28 AM   #3
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Get in there and start looking around. There are lots of areas where water can splash ,or, collect and leak. I went over mine with caulk at every joint, seam, and screw.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 06-07-2008, 05:28 AM   #4
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Use some big eyes and you will see some areas which need caulk. I took a lot of time a examined my shower install and caulked some areas which let water leak out, you could not seem them with the naked eye.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 06-07-2008, 11:12 PM   #5
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
It's under warranty, I wouldn't mess with it.
Take it to Bellflower (C&J?) I've heard good things about them.
You need to have this problem documented under warranty in case you have future problems with it.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 09:10 PM
rain leaking thru a/c Tarheel Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-19-2007 08:22 PM
Part missing? leaking shower connection glacierrunne Sinks, Showers & Toilets 3 07-18-2006 09:33 PM
A/C leaking atvmcg Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-18-2005 03:23 PM
Is my commode leaking? Fooltime Sinks, Showers & Toilets 5 04-16-2002 09:24 AM
