Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 12-12-2006, 06:56 PM   #1
janetb
janetb's Avatar
Profile:  2007 25' Safari FB SE
Aptos , California
Leak no more - tales from the toilet zone
We had a leak from behind the toilet, as I posted on the 07 SE sub forum, and thought I'd do the follow up here--in the toilet zone!
The problem was a compression fitting that was cross-threaded so it couldn't be screwed on tightly. The water came out in a small but steady stream, seeped under the partition, and saturated about a square foot of the bedroom carpet on the other side. This only happened when the line was pressurized. Terry had to remove the toilet to rescrew the valve on correctly, and now it's working as it should. Ta da. Easy fix.
Because it had been absolutely pouring buckets for a couple of days, we were worried about problems with vents, roof etc, but so far we are nice and water-tight.
So nice to have such a boring issue to report on.
Janet
janetb is offline   Reply With Quote
Old 12-12-2006, 07:02 PM   #2
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Good News - quite the handy man.
Happy Camping
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 12-12-2006, 07:20 PM   #3
janetb
janetb's Avatar
Aptos , California
Yes he's quite handy. Actually he's a bldg. contractor, and as you can imagine he has the honey-do list from hell waiting for him every weekend. No problem getting him to work on the Safari though! I have a feeling there are a few more of you like that out there...
Janet
Old 01-07-2007, 04:11 PM   #4
boonskyler
Profile:  1980 28' Excella II
Schuyler , Virginia
hi, i have the same problem, the leak behide the toilet, only happened when the line was pressurized. do you think Terry would mind to give a step by step to fix the problem.
thanks
boon.
boonskyler is offline   Reply With Quote
Old 01-07-2007, 08:14 PM   #5
janetb
janetb's Avatar
Aptos , California
Hi Boon,
Terry here (Janetb's husband)--The leak was where the supply line connected to the toilet. There wasn't enough room for me to get a wrench on the compression nut, so I had to remove the toilet for access. Only two bolts hold the toilet--just pop off the plastic nut covers first. The supply line on our Safari is flexible, so I was able to move the toilet away from the wall just enough to loosen and rescrew the compression nut so that it was threading properly, and then tighten it. Before you reseat the toilet check for leaks. No wax ring is required. I was surprised that the toilet only weighed a couple of pounds.
Good luck!
Old 01-07-2007, 08:23 PM   #6
CA Streamer
CA Streamer's Avatar
Profile:  2005 28' Safari S/O
Atascadero , California
Images: 11
Janet\Terry,
Did the leak occur only when connected to city water, and not when running from the storage tank? If so, you may want to use a water pressure regulator available at any RV store, or online. RV water systems are fairly low pressure so it's advisable to use one so you don't blow out the water lines.
Steve
Steve-- "Mongo only pawn in game of life"
CA Streamer is online now   Reply With Quote
Old 01-07-2007, 09:07 PM   #7
janetb
janetb's Avatar
Aptos , California
Hi Steve,
We're not sure if we had a leak with city water hook-up since we didn't use the toilet until our dry-camping shake-down, using the pressure pump. But it was definitely a result of cross-threading and not a pressure issue. All is good and dry since the fix, and a fairly significant amount of use, pressurized and otherwise.
We were told our Safari has a built-in pressure regulator, although we're thinking of adding one at the spigot site just to make sure the supply hose doesn't have an aneurism..
Thanks for your input!
Janet
Old 01-17-2007, 09:41 PM   #8
boonskyler
Schuyler , Virginia
thanks Terry/Janet, when the weather is nice I will see if I can remove the toilet to see if I can fix the problem.
thanks again.
boon.
Old 01-18-2007, 12:03 AM   #9
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I had a similar leak on the '98 Safari. It leaked at the plastic supply fitting behind the toilet - mainly under street pressure, even with a pressure regulator. I was able to tighten mine without removing the toilet, problem solved.
Fyrzowt is online now   Reply With Quote
Old 05-14-2007, 01:25 PM   #10
Fenghuang
Fenghuang's Avatar
Profile:  2007 23' Safari SE
San Diego , California
Thanks Terry/Janet for your helpful post. We just discovered the same toilet leak at the end of our 5th trip with our 2007 23' Safari. Luckily, the leak was resolved with some hand tightening of the plastic supply fitting.
Larry
"The only ones among you who will be really happy are those who will have sought and found how to serve"
Albert Schweitzer
Fenghuang is offline   Reply With Quote
Old 05-14-2007, 02:51 PM   #11
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Another leak that sometimes occurs is with the spray rinse hose that comes on the Classic toilets. If the nut that attaches the hose to the toilet is loose or cross threaded, you will get a water leak every time you flush the toilet. It's one of those that normally you will not see drip until you step on the pedal.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 05-14-2007, 03:57 PM   #12
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
If you have access problems to loosen and re-tighten that nut, try a crow's foot socket. They usually provide me access in the wierdest places where a conventional wrench won't fit.
BTW, if you have any of the 'newer' plastic water fittings, they should only be hand tight as the threads DO NOT DO THE SEALING on this fitting. There is a saniprene seal on the inside of the fitting and pressure from the threads causes it to seal against the male fitting. Too tight in this case WILL cause more leaks. ....and possibly crack.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 2 10-16-2002 08:39 PM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Do I have a leak? melprice Water Heaters, Filters & Pumps 6 06-24-2002 08:35 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
