Old 03-30-2014, 11:28 AM   #1
London
leak in water pipe under shower tray
Hello. I have a 1976 Tradewind based in the UK. Was recommissioning after winter yesterday and a water pipe (probably the hot water pipe) has sprung a leak under the shower tray in the rear bathroom. The tray is the original an all-in-one-fibreglass piece with built in seat. I wondered if anyone knew how I could access the pipes without removing the tray as I am sure it will split when trying to remove it. Thanks.
Annikins212 is offline   Reply With Quote
Old 06-08-2014, 07:11 AM   #2
1969 21' Globetrotter
Foley , Alabama
I just read your post and have experienced the same problem, have you any insight into how to fix this problem?
Mick33 is offline   Reply With Quote
Old 06-09-2014, 09:11 AM   #3
London
It proved relatively easy to fix. I removed the adhesive on the front wooden panel which exposed the pipe work and I could see it was a loose hot water pipe causing the problem I tightened that and replaced the panel and as good as new. But don't forget she's an old 1976 Airstream and it may well not work on newer models. Good luck A
Old 06-13-2014, 04:56 AM   #4
Foley , Alabama
Hey thanks Annikins212 for your post, I will attempt to do the same. I have a 69 model, maybe I'll get lucky also. Diving into it this weekend, I'll post an update when I discover the problem. Thanks again...
Water lnlet Pipe Leak - Fixed TankerIP Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 08-28-2012 09:24 PM
Dish/Glass Tray from '65 Safari? Clapper82 1965 Safari 0 12-16-2006 08:10 PM
Rear bumper storage tray - 2004 Classic Ed Keyes 2001 - 2005 Classic 9 10-02-2005 09:50 PM
pan/tray for convection/pantry shelves,etc wingsofgold1 Airstream Motorhome Forums 0 11-05-2003 02:39 PM
battery tray lido&linda 85/345 Mechanics Corner - Engines, Transmission & More... 3 09-16-2003 09:33 PM
