Old 07-27-2009, 06:48 AM   #1
Streamer Jabe
Jabreyd13's Avatar
1978 31' Excella 500
Edmond , Oklahoma
Leak in Bathroom, Toilet I think. What to do?
Hello All,
While dealing with electrical issues and going back and forth from my A/C breaker box in the rear to my 12 volt fuse panel in the very front, I noticed this morning that my carpet in the bathroom was wet. I believe it's coming from under the toilet, but I can't tell for sure and don't know how to identify where it's coming from. I opened up the back hatch up, and nothing is physically leaking in there, but I can see the wetness coming into there from the bathroom. I have a thetford aqua magic toilet, and don't know what to do to check it. I have shut off my water supply until I get this figured out. Any and all help is welcome
Jabreyd13 is offline   Reply With Quote
Old 07-27-2009, 09:30 AM   #2
Seymour1971's Avatar
1971 21' Globetrotter
Western US Cities , CA,AZ,NV,UT,OR,WA
Jabreyd13
You may need to pull the toilet in order to determine the cause of the leak. Easy job. Only two bolts hold the toilet in place. This may also give you a chance to check the main gasket under the unit. My unit was leaking at the initial connection between the water line and the toilet. I could feel the leak but would have never been able to see it or fix it because of the limited access. In my case, a PO used a steel threaded male extension to attach to the plastic female part on the toilet. At some point, it was over tightened and the plastic portion cracked. It must have held for a while since I only noticed the leak recently. Your leak may also be coming from the hose fittings that are found within the toilet. In my case, one supplied water during flushing and the other feed the water saver hose. Now I wish I would have taken pictures of the underside of the unit I replaced. Hope this helps a bit.
Mike
Seymour1971 is offline   Reply With Quote
Old 07-27-2009, 09:40 AM   #3
Streamer Jabe
Jabreyd13's Avatar
Edmond , Oklahoma
bolts
where are the bolts located?
Old 07-27-2009, 09:59 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If it's a Galaxy/Starlite here is the manual. Parts are available here:
Marksrv.com Thetford Galaxy and Starlite toilets and parts
If it's the plastic piece the copper line connects to (our problem) We replaced that coupler from a hardware store. The feed line was changed to 4 or 5' stainless hose from Home Depot with the appropriate brass couplers. That took the rigid copper pipe pressure off the toilet fittings. Good luck with your repair.....
Old 07-27-2009, 01:30 PM   #5
Jabreyd13,
Take a look behind the foot petal. You should be able to see it. Again, that picture would have come in so handy for you. Very similar to a house toilet bolt minus the decorative cap. Depending on hour your mounting bracket was attached will determine how easy they are to access. At the very least, you should be able to see one when you look behind the foot petal. The PDF above has a great visual of where they are located. Good luck.
Mike
Strange toilet leak Anniedog Sinks, Showers & Toilets 4 09-26-2008 11:20 AM
Leak in 94 Excella bathroom ernesto ca Sinks, Showers & Toilets 1 08-11-2008 03:45 PM
Leak behind toilet granaudio All Argosy Trailers 21 07-17-2008 11:48 AM
Help! Toilet leak Aria Sinks, Showers & Toilets 21 06-14-2007 02:55 PM
Help on leak in toilet...? escapeez Sinks, Showers & Toilets 2 08-03-2003 05:40 AM
