Old 08-11-2008, 03:39 PM   #1
ernesto ca's Avatar
1994 34' Excella
Arabela , New Mexico
Leak in 94 Excella bathroom
After winterizing my 94 excella 34 footer and attempting to reintroduce water to the system. I had a difficult time getting pressure to sinks both br and kit even with the pump. As soon as I connected to full hook-up everything seemed fine. EXCEPT I noticed a sizeable leak in the bathroom floor but couldn't find the source. Am I faced with a toilet leak of some sort? I checked the three valves under the bathroom sink but there was not an obvious leak or cracking. Maybe something cracked or broke in the supply line to bathroom?..Thanks for any input..Ernesto
ernesto ca is offline   Reply With Quote
Old 08-11-2008, 03:45 PM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Ernesto,
Are all your low point drain valves closed?
Could the leak be coming from the water inlet valve at the toilet?
Does the pump run and stop or run constantly?
There are a lot of possibilities, start simple and work towards the complicated.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 10 01-05-2010 06:30 AM
towing the 32 excella vs 34 excella hitch recommendations lakelady Hitches, Couplers & Balls 21 03-21-2008 07:13 PM
77 excella 500 bathroom vent problem tschat Roof Vents, Skylights & Fans 2 11-22-2006 06:26 PM
79 Excella Bathroom redo zamboni Cabinets, Counter Tops & Furnishings 0 03-25-2004 08:23 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
