Old 10-10-2015, 04:55 PM   #1
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
leak from under kitchen sink - gasket?
Relatively new 2013 Flying Cloud 30. I have a leak under the kitchen sink. All of the pipes in the P-traps are tight and that does not appear to be where the leak is coming from. It seems like the water is coming from the base of the sink where the drain is. There looks to be a gasket in there that is the source of the leak. Can anyone help with how to take this apart to get access to the gasket and replace it? It looks like the drain is glued in. I donít want to try to cut this out if I donít have to.
RAH is offline   Reply With Quote
Old 10-12-2015, 10:53 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I would think it just like the sink you your home. Unscrew the P trap and then unscrew the drain from below the sink to remove from the top. You can use plumbers putty between the sink lip and the drain. As you tighten the putty squeezes out. Remove the excess. Hook up the P trap and test for leaks.
Kelvin
Old 10-12-2015, 11:26 AM   #3
Mission , Texas
Video ...
nrgtrakr is offline   Reply With Quote
Old 08-01-2017, 11:10 AM   #4
2017 23' Flying Cloud
Danville , California
Leaking sink on 2017 FC as well
Have had a leak under the sink as well on a 2017 23' FC. Checked all fittings and dealer even pressure tested. I'll try the gasket on the drain, but what about the sink itself? i.e., no silicone or sealant put in the rim of the sink when installed.
Anyone run into this?
Portiemobile is offline   Reply With Quote
Old 08-01-2017, 12:00 PM   #5
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I had the same leak after about 3 years. I unscrewed the drain fitting from the sink and found that Airstream had not used any plumber's putty when installing it. The putty goes between the sink and the drain fitting, assuring no leakage. All is well, now.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-01-2017, 12:43 PM   #6
Missouri Valley , Iowa
My 2017 26U Flying Cloud has an intermittent leak under the galley sink. But mine is caused by the drain tubing being cut too short so that the drain won't tighten squarely against the bottom of the sink. I'll fix it myself by lengthening the vertical drain pipe an inch or so. QC not so good on this drain. But most everything else is good - so far !!
Dan
Farmer Dan is offline   Reply With Quote
Tambour door for under kitchen sink Dutchman Ray Interior Restoration Forum 12 02-14-2015 05:31 PM
'71 23' Safari Twin Forced Hot Air Vent under kitchen sink Kei Airstream Classifieds 0 06-02-2014 10:07 PM
Water Pump under Kitchen sink Airdaddy Water Heaters, Filters & Pumps 8 10-29-2009 09:05 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
