Old 02-24-2015, 08:28 AM   #1
To Gulls
To Gulls's Avatar
2007 25' Safari FB SE
Pensacola , Florida
Leak below shower....help!!!!
I thought this was coming from the door but now I am not so sure? How to find source of leak?
Name:	ImageUploadedByAirstream Forums1424791663.517710.jpg
To Gulls
Tami & Brenda - Pensacola, FL
2007 25FB Safari Special Edition LS
2008 White Toyota Tundra 5.7L V8
"There is no present like the time."
To Gulls is offline   Reply With Quote
Old 02-24-2015, 08:39 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Can't really decipher the photo.
My shower leaked to the floor and it was the plastic flashing surrounding the inside of the shower door frame that was allowing water to leak down to the hallway floor. If the shower drain is leaking then the water would drip through the drain pipe hole to the belly pan. Mine was leaking slightly too. I accessed it through a heating vent in the front bedroom. Tight squeeze. I was able to unscrew the pipe and found a flat rubber washer. Not a good design. I eventually used some clear silicon on the flat washer and seems to have fixed that leak. The shower faucet could be leaking. Open the access panel in the wardrobe to see any evidence. Are there any cracks in the shower floor pan?
Kelvin
HELP! Water leak In 2005 Safari 28W Coming from behind shower? Shirley C Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 12-30-2012 06:51 PM
City Water fitting/leak below Denis4x4 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 10-22-2007 05:25 AM
Yikes! A leak... from below? pamelake General Interior Topics 9 03-02-2007 11:40 PM
Shower Leak - Help! dmac Sinks, Showers & Toilets 4 10-16-2006 07:24 AM
H2o leak from below (hot H2O tank ?) bigwoody Water Heaters, Filters & Pumps 3 09-27-2003 06:57 PM
