Old 03-25-2019, 09:32 AM   #1
2018 22' Sport
MARIETTA , Georgia
Leak Behind Shower from Hose.
I found a leak yesterday behind the the shower where the hose attaches through the shower wall. It only happens when the the shower main valve is on and the the shower head valve is closed. I have a 2018 22 sport.
Itís easily accessed. Iím sure under warranty but donít want to wait for ever to get it fixed by dealer. Would you do it yourself or take to dealer? I think I could come up with a better solution. See pics! Click image for larger version
ID:	336522Click image for larger version
Pthorpe4080 is offline   Reply With Quote
Old 03-25-2019, 09:41 AM   #2
2019 27' Globetrotter
Salem , Oregon
I think you just answered your own question. Most dealers are always behind. Long wait, distance to dealer etc. Take a look yourself first.
Just my 2 cents. Dave
NoResults is offline   Reply With Quote
Old 03-25-2019, 09:41 AM   #3
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Itís easily accessed. Iím sure under warranty but donít want to wait for ever to get it fixed by dealer. Would you do it yourself or take to dealer? I think I could come up with a better solution. See pics! Attachment 336522Attachment 336523
Hi Pthorpe4080,*
We're very sorry to learn about your leak. If you need assistance, please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 03-25-2019, 09:48 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
We noticed the same leak the first time we turned the shower on,(at home when I did a real PDI)👎,...our supply line was too short...say hello to Home Depot. I used a flexible supply line, ie sink, instead of the pex that they couldn't cut to the proper length.
From your photo it appears a quality install, but like the work/sealing on the roof, it's OOSOOM, never to be seen again🥴
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-25-2019, 10:12 AM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we had the SAME leak in out as22FB
we got it fixed by CANAM in London
waninae39 is offline   Reply With Quote
Old 03-25-2019, 11:12 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I would fix it. But I already have the PEX crimpers.
Bill M. is online now   Reply With Quote
Old 03-26-2019, 08:51 AM   #7
2018 22' Sport
MARIETTA , Georgia
Leak
[Thanks, the last digits of vin are 541044
Peter Thorpe
51 Whitlock Dr SW
Marietta Ga 30064
770-527-3207
Pthorpe007@gmail.com
QUOTE=AirstreamInc;2223831]Hi Pthorpe4080,*
Thank you.*[/QUOTE]
Old 03-26-2019, 09:49 AM   #8
Depends :) , My heart is in Colorado
in our 2006 25FB, I discovered a pinhole leak in the PEX in just that area last year. It gave me a good excuse to buy crimpers. It is a slightly awkward area to work in, but a satisfying do it yourself plumbing job.
If your dealer doesn't take care of, we'll support you here!
-Paige
Jump, and the net will appear.
Papatango is offline   Reply With Quote
Old 03-26-2019, 12:09 PM   #9
The Silver TARDIS
Kevinshortnh's Avatar
2018 30' Classic
Gray Court , South Carolina
We had a similar issue that was fixed by our dealer the morning after we took delivery. (We spent our first night at the dealer, Pete's RV in Vermont.) It seems that the wood shim was a little too thick, so not enough pipe threads were tightened to prevent leakage. Their solution was to make a thinner shim so they could get enough pipe thread twists to prevent leakage.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
Kevinshortnh is offline   Reply With Quote
Old 03-26-2019, 12:10 PM   #10
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
If I read your post correct it is at the wall joint not the PEX fitting??..... if pex I prefer the solid metal rings ....if wall is the screw fitting just loose??
rucos is offline   Reply With Quote
Old 03-26-2019, 12:18 PM   #11
Silver Star
rucos's Avatar
1970 23' Safari
I would do it ...first clean off excess caulk and determine is it the pet joint or screw joint that the actual water is leaking from ....then you can figure for sure what's to do.
Old 03-26-2019, 07:12 PM   #12
CruizinDux's Avatar
Tracktown USA , Oregon
FWIW, I had a similar situation at my FW connection. Mid trip once i noticed water pouring out if the belly pan under the fw/bw connection. After some investigation, it turns out (so to speak) that the connection was loose...almost a whole turn on the male thumb connector. The BW was a bit loose too but not enough to leak. Now i check all accessible connections at the start of each trip.
B
CruizinDux is offline   Reply With Quote
Shower leaks behind shower surround Divemaster10 Sinks, Showers & Toilets 6 05-15-2018 03:21 PM
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 01:53 PM
HELP! Water leak In 2005 Safari 28W Coming from behind shower? Shirley C Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 12-30-2012 06:51 PM
Leak Behind the toilet/shower panel - Help SNOBORDJON Fresh Water Systems 8 05-25-2009 06:58 PM
Leak behind shower base cookeville34 Sinks, Showers & Toilets 0 09-13-2006 08:12 PM
