The lavatory faucet in our "05 25' Safari is of the double valve type (one for hot and one for cold). Even though it operates perfectly and is nice looking, I would like to replace it with a single handle lever type. Can I just go to Lowes or Home Depot, buy one that I like and install it, or is there some special type for an Airstream?
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Thank you Gary. As soon as we return home from our big trip. We will be picking out a new faucet.
hi moosetags, any tip on replacing faucet?, i bought 1980 excella II a week ago, and afread to turn on anything, today try to clean the bath tub, when i turn on the faucet handle, the handle and the stem came out, water pure out like crazy, did not know the switch for the pump is, finaly found it and turn the switch off. on the bright side the pump is working, now hopfully all i have to do is replace the faucet.
boon.
The hot handle of my lavatory sink faucet is loose (2005 Safari). There does not appear to be any hex nut by which to tichten the handle. How do I retighten the handle?
Neil Ervin, Phoenix, Arizona (Sun City Grand)
Not sure what type of handles your unit has, but ours have a rather large round piece just below the handles. Our handles sometimes comes loose from wiping them clean. To tighten we turn the round piece. Turn it one way to tighten and the other to take the handles off. BTW we have an 04 Safari w/ upgrades. Hopes this helps.
Best,
This is the new single handle that we installed several months ago. It was the second one that we installed. The first single handle did not have a long enough reach into the sink.
Neil -- This happened to my '06 about a year ago. I searched the manufacturer's website & found a diagram. Instead of repair I only had to tighten it well -- IIRC I had to get to the underside. I don't recall more -- I'm bringing my Safari home tonight to prepare for a weekend trip. I'll post again if anything rings a bell. My impression is that the fix was actually quite simple.
