Old 01-09-2019, 02:19 PM   #1
2005 28' International CCD
Pittsburgh , Pennsylvania
Lav Sink Drain Problem
Can't figure out how to clear the lav sink drain in my 05 CCD Intl. I know the problem is at the stopper, not further down. Can't figure out how to remove stopper.
Bilo Hak is offline   Reply With Quote
Old 01-09-2019, 02:40 PM   #2
2007 22' International CCD
If this is the kind of stopper that is pushed down on to open and close it, it should unscrew from the drain. Usually is a threaded stud on the bottom that screws into a X-shaped part lower down in the drain that has a threaded hole in it. It may be seized up with corrosion and mineral deposits.
If the problem is just a big hair clog, the big box home improvement stores sell a drain clearing gadget that is a long narrow strip of yellow plastic with a pull ring at the top and a series of sharp 'hooks' that will grab the clog as you thread this gizmo down the drain and then pull it out carefully. Usually in the plumbing repair department with the stuff for sinks.
https://www.homedepot.com/p/BrassCra...0112/305468409
I used one on some hair monster clogs caused by DW and Daughter, and it cleared them right out without disassembling the sink or drain plumbing.
Old 01-09-2019, 03:30 PM   #3
2018 28' International
Fayetteville , Georgia
Take the P-trap off and clean out from below.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 01-09-2019, 04:18 PM   #4
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
See Post #2
I second the unscrew advise.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 01-09-2019, 04:47 PM   #5
Long Island , New York
Try both IMO:
brick
OTRA15 is online now   Reply With Quote
Old 01-09-2019, 06:27 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Similar to yours, not exact. But you will get the idea.
or this
Alan
Asheville Newbie's lav sink not draining--separate valve? meghanhester Sinks, Showers & Toilets 2 08-06-2012 09:55 AM
Broken '79 Argosy lav sink nick6930 All Argosy Trailers 9 02-17-2009 06:58 AM
removal of 63 globetrotter sink & lav faucets? ChicknKathy Sinks, Showers & Toilets 2 03-05-2007 08:04 AM
lav sink fell apart in '71 Safari mtpalms Sinks, Showers & Toilets 10 07-18-2005 06:27 PM
Argosy lav sink reconfiguration? Janet H Sinks, Showers & Toilets 7 02-25-2005 03:56 PM
