Old 06-28-2010, 04:43 AM   #15
1978 28' Ambassador
Savannah , Georgia
Toilet installed over laminate floor
Completed installing toilet over laminate floor. Attached new underlayment pad, eased flooring under floor flange, sealed all edges with caulking (silicone for once) and added back moulding to prevent water from going out behind toilet. The screws to attach flange to floor were #6 x 3/4" and I used #6 x 1 1/4" stainless. One of the original screws was not even attached to the floor. All six screws went in with little effort once I found the holes with an icepick. Fun part was putting nut on bolt at the back of the toilet. Thank you duct tape inventer. Could not have done it wthout all the help here. I am real happy with the outcome. Time will tell if this works. Thanks. Jack
ID:	105814   Click image for larger version
ID:	105816   Click image for larger version
Skamper1 is offline   Reply With Quote
Old 06-28-2010, 05:46 AM   #16
Bettye's Avatar
2010 25' FB International
Mobile , Alabama
Images: 18
Looks great! We still have the carpet and it's gotta go!!
Bettye & Harry
WBCCI #10360
Member Southeastern Camping Unit
Bettye is offline   Reply With Quote
Old 06-28-2010, 09:41 AM   #17
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Jack, I see your photo up in post #15 of the flooring. I'm surprised you didn't need to make a cutout for the toilet valve pedals. My flooring prevented the pedals from moving all the way down.
Zep
Old 06-28-2010, 10:17 AM   #18
1978 28' Ambassador
Savannah , Georgia
That was the reason I wanted to place flooring completely under the toilet so I would not have to cut out for flush pedal. It works great! Pedals go all the way down with room to spare from laminate. Previous pics show where I had done a cut-out for the pedal. All I could think was that there would be a place "stuff" would collect I could not clean. Although I have not "used" toilet, trust me it is getting flushed and checked very often. Thanks for all your advice. Jack
Old 06-05-2011, 08:13 PM   #19
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I'm going through the same problem with new cork flooring.Anybody know if this flange will allow me to install the toilet like normal on top of the flooring.The threaded part of mine is about an 1" to 1 1/4" and if this one listed hear measure's the 1 3/4" I'm thinking the description specifies.
LaSalle Bristol Plastic Closet Flange 3" x 1-3/4" MPT - Toilet Accessories - Toilets - Plumbing
desertair27 is offline   Reply With Quote
Old 06-08-2011, 12:28 PM   #20
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
so I figured out that my last post pertaining to the closet flange won't work.Time to figure something else out.
Any other ideas?????
Old 06-13-2011, 09:23 AM   #21
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Looks like I'm going to install the original closet flange on top of the new cork flooring and cross my fingers it works.Looks like I have some flex in the black tank and the 1/2" extra depth of the new floor should be ok.I'll post pictures soon.
bubbled up wood laminate floor in 2008 Randjg1 Floor Finishes 6 06-10-2009 08:04 PM
can't get the toilet bolted to the floor marblesyoga Sinks, Showers & Toilets 6 07-05-2008 10:25 PM
'tricks' to laying a laminate floor? 59er Floor Finishes 4 07-06-2007 10:06 AM
Floating Floor/Laminate Question soldiermedic Repairing/Replacing Floor &/or Frame 44 11-05-2006 05:58 PM
Laminate Floor Trim? Steve Heywood Repairing/Replacing Floor &/or Frame 5 12-18-2005 06:41 PM
