Old 07-30-2011, 06:47 PM   #1
lcurrie's Avatar
2005 19' Safari
Kitchen Sprayer Leaking
Hi All,
The sprayer on my 2008 Bambi drips/drizzles water from the base of the sprayer. I took it apart and the O rings look good. There is a white plastic part that attaches to the hose but it doesn't look like anything I can tighten. Thoughts on what else to check?
Thanks!
Lynn
Lynn
Austin, Texas
2005 19' Safari, Toyota Tundra
2 Small and Spoiled Dogs
lcurrie is offline   Reply With Quote
Old 07-30-2011, 07:44 PM   #2
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
That appears to be a common problem as many others have noticed it too. If the leak isnít stopped it will in time cause the floor to buckle and eventually rot the plywood floor. Not good.
The first year I called the OEM (Delta, I think) and they sent me a new on for free. But since it is difficult to get to the hose, I replaced jut the sprayer part. Worked well for a couple years and now it is leaking again. I might cut hose and seal it up.
I could replace the whole faucet assembly with a better quality unit, but that looks difficult working in such very tight space. Might be easier to pull the sink first to access the fittings. Do we even need the sprayer? Good Luck.
JStanley is offline   Reply With Quote
Old 07-30-2011, 07:49 PM   #3
lcurrie's Avatar
2005 19' Safari
Thanks for the info. I suspected as much since it's all plastic.
I will probably just replace the entire faucet with a pull out handle. Then all I'll have to do is figure out what to put in the hole in the countertops!
Lynn
Old 07-30-2011, 08:31 PM   #4
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I have a Mohen single handle sprayer from our Bambi if you want it. I could bring it to the rally.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 07-31-2011, 07:55 PM   #5
blmitch5's Avatar
Olathe , Kansas
Lynn
A soap dispenser!
WBCCI 4973
Old 08-01-2011, 08:19 AM   #6
lcurrie's Avatar
2005 19' Safari
Thanks for the offer to bring your extra sprayer!
I'm going to replace the faucet, but not until we get back from the rally. I didn't want to get into a plumbing project and not be able to finish it before we needed to leave. The bonus will be that I'll get to see everyone else's faucets and get the pros and cons of each style!
Lynn
Old 08-01-2011, 12:01 PM   #7
blmitch5's Avatar
Olathe , Kansas
I replaced the Moen with a more stylish one from IKEA. No sprayer but it has a pull out handle.
WBCCI 4973
Old 08-01-2011, 04:38 PM   #8
idmtman's Avatar
Worley , Idaho
Our sprayer leaked this spring and I tried to repair it. Didn't work, replaced it with the same original product purchased at Lowes; no leaks. I suspect it had some water in it that the PO didn't remove when he winterized. Pretty easy fix. It takes about 3 minutes to replace.
Idmtman
2006 Safari 28' SE (Sylvia)
75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
idmtman is offline   Reply With Quote
Old 08-01-2011, 05:05 PM   #9
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Ours cracked one winter because I forgot to run antifreeze through it. It is very cheap plastic and a hairline crack can be hard to see. It got replaced under warranty, but if it happens again, I may replace the whole faucet if I can figure out how to deal with the filter system. Ours has a third valve that dispenses filtered cold water part way up the spigot. Maybe it would be easier to replace the sprayer with a good quality metal one.
Gene
1997 Limited Classic 34' Front Kitchen?? TomR 1993-1997 Limited 20 11-20-2015 07:03 PM
Portable Kitchen - the ideal AS Charcoal Grill tarheel1972 Full-Timing 25 08-03-2011 03:41 AM
HELP! kitchen window leaks Jcashcollect Windows & Screens 4 06-23-2011 10:41 AM
Sometimes I think my Airstream is playing tricks on us! Leaking issue . . . J5MM 2006 Safari SE 4 04-16-2011 06:58 AM
64 bath sink sprayer donh1 Sinks, Showers & Toilets 5 01-11-2011 05:11 PM
