Old 01-05-2014, 05:55 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Kitchen Faucet Removal - '66 Trade Wind
I learned today what happens when you have a zinc nut on a brass valve with a steel back up washer. After 48 years they all become inseparable! It made the simple job of removing the kitchen faucet a nightmare. I soaked the threads for two days to no avail.
I thought sure my 1 1/16 socket would break the nut loose, or break the housing, but no. I finally had to saw it off, all while working under the kitchen sink.
I post this as a warning to those who have a "honey do" list for the trailer that says "new kitchen faucet". Sounds easy, but you should procrastinate as LONG as possible.
David
Name:	1401 Galley Faucet Removed.jpg
Old 01-05-2014, 07:44 PM   #2
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey David
At least the replacement faucet should be an easy install. Except for having to work on your back in a tiny cabinet with water dripping on your head!
Stay warm,
Tim
Beaker63 is offline   Reply With Quote
Old 01-06-2014, 06:11 AM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I am hoping she will pick one that I can assemble flex hoses on the bench and then slip it through the holes in the counter tops. Then I only have to tighten the faucet clamp bolts. I can connect the hoses to my PEX fittings and be done. But I doubt I will be that lucky.
David
Old 01-06-2014, 07:43 AM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I just did mine a few months ago. It was a newer trailer so I didn't have the long term corrosion to deal with and it came off easily. I replaced it because Moen no longer supports or makes filter cartridges. They sent me a new faucet with no internal filter. The new ones come with pull out sprayers come with long flexible lines attached at the faucet side so you only need to attach at the supply end. May need an adaptor fitting to make that connection. If I recall the supply end was 0.5" and the faucet line was 0.375" or something like that.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-06-2014, 10:06 AM   #5
1974 Argosy 20
Kooskia , Idaho
On one bathroom sink faucet on an older AS or Argosy I had (can't recall which one) I finally resorted to a sawzall solution from the top to remove the damn thing. As you can imagine, I had to be very very careful when doing that so as not to wreck the sink and countertop.
Old 01-06-2014, 03:59 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Idroba,
Yep, I had to retreat to the sawzall too. A man's second best friend! The bathroom faucets are still attached to the sink and tub. I cut the copper as I am re-plumbing the trailer, both fresh water and drain lines. I'll probably have ten questions on that project once it starts.
David
'68 Trade Wind Small Lower Window Removal 68 TWind Windows & Screens 6 08-21-2009 08:34 PM
Kitchen Sink Removal, 69 Trade Wind Captain JJ Sinks, Showers & Toilets 1 07-27-2009 12:49 PM
Installed new kitchen faucet! Stefrobrts Fresh Water Systems 18 07-16-2004 11:33 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
