Old 04-17-2010, 10:50 AM   #1
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
Is there a special P-trap wrench?
On my 58 Flying Cloud I need to replace cracked/leaking p-trap that hangs slightly out of the belly pan. There is a "patch" of aluminum that can be unscrewed to access, but it's only about a foot square. My problem is that I can't get a normal wrench up in there to spin off the nuts. Some plumber must have had a similar access problem and needed a wrench with some reach. Know of anything?
bevman is offline   Reply With Quote
Old 04-17-2010, 10:56 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
A basin wrench might help you. Amazon.com: Superior Tools 11-Inch Basin Wrench: Home Improvement
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-19-2010, 04:04 PM   #3
bevman's Avatar
this is certainly the right idea... but do they come with jaws big enough to manage a p-trap nut? (I have one of these and have used it to install sink faucets.)
Old 04-19-2010, 04:18 PM   #4
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
If you can't access the leaking trap, how about the other nuts? Maybe you can remove the drain from bottom of sink & another point in drain line. Then you can remove it as an assembly. Reassembling with new parts should go easier as you won't need to exert the strength that's needed to break something loose.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 04-19-2010, 05:04 PM   #5
Images: 59
Does it look like a regular tube P-trap, or is it a cast iron P-trap like the picture below?
If it's like mine ('59) you remove it by unscrewing the drain trim from above.
Old 04-20-2010, 09:17 AM   #6
1967 22' Safari
1960 Caravel
Images: 8
That's what the p-trap on my 60 looks like.
Can you post a pic of the p-trap bevman? A basin wrench does come in different sizes.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 04-21-2010, 08:50 AM   #7
bevman's Avatar
I'll get out there when the rain stops (soon) and get some pix. It is just a brass u-shaped standard plumbing p-trap (not cast iron). The bottom third of it hangs outside the belly pan skin. It's somewhere under the shower pan and I think that it's attached to the shower drain. I'm unclear as to the routing of the grey water system (58 didn't have a grey tank so it's just a passthrough and out). There is a vent stack in the closet between the galley and the shower stall. I assume that the grey water line is a straight shot from the galley sink back along the curb side to the outfall, with the drains attached along the way. The "tee" where the floor mounted black tank joins the grey water line is a total mystery since I've never had the belly pan off.
Old 04-21-2010, 09:57 AM   #8
Right-- if it's original Airstream equipment, you need to remove it from above, while holding the nut still from below with an open-end wrench or crescent wrench or even a pair of large-jaw pliers or channel locks, whatever you can get on there.
From above, the drain has a "+" shape in the middle of it, and you can turn it out by using the special wrench that is made for such things:
BrassCraft Tub Drain Removal Tool - T170 at The Home Depot
Or, if you don't want to go to the hardware store or plumbing supply store, you can try using two screwdrivers crossed to get it out.
Depending on PO fixes over the years, there might be some kind of sealant between the drain and the pan. Putty, silicone caulk, etc. You should remove all of that with a razor knife (take care to protect your pan if you plan to reuse it) so that the drain can spin freely. Even then, decades of corrosion might make it difficult to remove. Hit it repeatedly with a heat gun and it should eventually break free (again, be careful not to overheat your pan if you plan to save it, try to keep the heat on the metal).
Good luck!
P-trap advice Zeppelinium Sinks, Showers & Toilets 4 02-10-2008 09:43 AM
$28.99 for a torque wrench... did I was my $ Kistler Our Community 3 03-11-2004 06:27 PM
P Trap Cup Chitown AirStreamers Plumbing - Systems & Fixtures 2 07-29-2003 02:34 PM
tub p-trap Paul Mayeux Sinks, Showers & Toilets 7 02-19-2003 11:24 AM
Wrench Sizes rmmm68 General Repair Forum 1 01-14-2003 01:05 PM
