Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-30-2009, 06:03 PM   #1
ryan3326's Avatar
Profile:  1976 31' Sovereign
Columbus , Indiana
is there a direct toilet replacement???
I cracked my Thetford Aqua Magic in my 1976 Sovereign middle bath and would like to know if there is a current manufacture replacement?
ryan3326 is offline   Reply With Quote
Old 08-30-2009, 07:57 PM   #2
Profile:  1998 28' Excella
Dolores , Colorado
You should be able to obtain one from Camping World. When we replaced ours in our Excella a couple years ago we upgraded to a china stool. Haven't regretted it. If you want to keep it "original" thne try contacting Inland RV to see if they have one.
Luck to you
4CU/CAC
WBCCI #10105
AIR # 28748
dogpound is offline   Reply With Quote
Old 08-30-2009, 09:02 PM   #3
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
The only original one will be out of another trailer of that era. Here is a conversion chart that may help you.... sorry to hear about your crappy luck with the old one....
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 08-30-2009, 09:34 PM   #4
Profile:  Spring Valley , Ohio
That conversion chart is slick! Should cover your original toilet.
Thetford is still making the Aqua Magic V in both high and low profiles and they are inexpensive and readily available, for example below.
Aqua-Magic V Toilets - Product - Camping World
One thing you may need to be aware of is that the old Aqua Magics had the two mounting bolts at a 45 degree angle whereas the newer ones are on a line parallel to the front of the toilet. So you may have to rotate the mounting flange 45 degrees to install the new one.
Or for a little more money you can install a porcelain SeaLand, which I believe is what the Airstream factory is using now.
Nuvite-F is offline   Reply With Quote
'67 toilet replacement 10brink Sinks, Showers & Toilets 2 08-29-2008 07:52 PM
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 08:51 PM
Toilet Replacement??? Dano57 Sinks, Showers & Toilets 4 07-24-2006 12:49 AM
Toilet Replacement Hawk_Man Sinks, Showers & Toilets 8 05-15-2006 03:38 PM
Toilet replacement Globestream Sinks, Showers & Toilets 2 09-23-2003 12:52 PM
